[CDO] Finding detached objects [message #905327] |
Thu, 30 August 2012 03:17  |
I have CDO objects that are referenced from a "data structure". I want to update that structure in one batch AFTER a successful commit. The problem is to find the objects that where detached in the commit.
I have tried a few options:
CDOSessionInvalidationEvent:
Seems like the perfect fit since it gives you a CDOIDAndVersion object for every added, changed or detached object after a commit (from anywhere). Finding the actual added and changed objects is easy using view.getObject(cdoIDAndVersion.getID()). BUT how do I find the detached objects in/from the committing CDOTransaction? You can't use the same view.getObject method since detached objects are no longer present in the committing CDOTransaction.
CDOViewInvalidationEvent:
Another seemingly perfect fit. Gives you added, changed and detached object instances from the view receiving the event. BUT this event doesn't get sent to the committing transaction, only to all other views.
So, how do I use invalidation events, or some other mechanism, to get the actual instances of still referenced but removed (from a CDO perspective) objects from the committing transaction?
///Anders
Re: [CDO] Finding detached objects [message #905331 is a reply to message #905327] |
Thu, 30 August 2012 03:22   |
Hi Anders,
You can attach a CDOTransactionHandler1 to your CDOTransaction to be
notified of attached/detached/modifyed objects.
Regards.
On 30/08/2012 09:17, Anders Jönsson wrote:
> Regards
> ///Anders
FUDForum. Page generated in 0.26864 seconds
