Home » Archived » BIRT » Problem charting datetime
Problem charting datetime [message #904363] Tue, 28 August 2012 06:23 Go to next message
I've created an oda to query and read responses from a webservice. I can get back dates in the results. I parse these results via:
return new java.sql.Timestamp(time.parse(sourceData.get(m_currentRowId - 1).get(index - 1)).getTime())
(m_currentRowId and index point to where in my sourcedata the date is.)
This produces a list of dates such as:
29 Jan 2012 20:40
27 Jan 2012 23:01
27 Jan 2012 21:53
29 Jan 2012 14:54
28 Jan 2012 09:05
27 Jan 2012 21:47
27 Jan 2012 19:45
30 Jan 2012 17:27
29 Jan 2012 12:09
28 Jan 2012 14:11
When I chart this using date time, grouping by day, a Jan 27th bar appears twice and Jan 28th not at all. By looking at the size of the bar chart I can tell it is thinking some of the 27th Jan are the same as 28th Jan and labelling this 27th Jan. There is then another bar of the rest of 27th Jan.
When I set the column type as Date (so all the times are the same) this problem does not occur.
Any ideas to why this is happening?
James
Re: Problem charting datetime [message #904615 is a reply to message #904363] Tue, 28 August 2012 16:29 Go to previous messageGo to next message
James
Can you post an image of the issue?
Jason
On 8/28/2012 6:23 AM, James Whitehead wrote:
> 29 Jan 2012 20:40 27 Jan 2012 23:01 27 Jan 2012 21:53 29 Jan 2012 14:54
> 28 Jan 2012 09:05 27 Jan 2012 21:47 27 Jan 2012 19:45 30 Jan 2012 17:27
> 29 Jan 2012 12:09 28 Jan 2012 14:11
> rest of 27th Jan.
> James
Re: Problem charting datetime [message #904859 is a reply to message #904363] Wed, 29 August 2012 05:32 Go to previous messageGo to next message
Hi Jason,
The print screen was taken of charts using 2 datasources based on identical data and set up, with the only difference being I changed the output column type to from date time to date.
I have also uploaded an excel file of the results shown in Preview results for each (thery are in random order but are the same data points).
Thanks for your help,
James
  • Attachment: chartProblem.JPG
    (Size: 64.08KB, Downloaded 256 times)
  • Attachment: dates.xls
    (Size: 34.50KB, Downloaded 338 times)
Re: Problem charting datetime [message #905042 is a reply to message #904859] Wed, 29 August 2012 11:29 Go to previous messageGo to next message
James
I am trying to recreate the issue, but it does not look like the dates
are the same in the xls sheet. BTW do you have aggregration on the
x-axis disabled? Is the x-axis type set to date time? What are you
using for the y-axis values?
Jason
On 8/29/2012 5:32 AM, James Whitehead wrote:
> Hi Jason,
> James
Re: Problem charting datetime [message #905052 is a reply to message #904363] Wed, 29 August 2012 11:42 Go to previous messageGo to next message
The data may be shuffled up but the dates are the same (if you get excel to sort them into order using data->sort then you should see they match up, with just the time being different.
The x-axis is set to group type: date time, unit: days, interval: 1, aggregate expression: count
y is set to date again but aggregated by count.
Thanks for your help, I have no idea what is going on.
Re: Problem charting datetime [message #905074 is a reply to message #905052] Wed, 29 August 2012 12:27 Go to previous messageGo to next message
James
I dumped your dates to a csv and I get the exact same charts when I
change the x and y values to be date or datetime. Are you setting the
data types in the oda correctly?
Jason
Re: Problem charting datetime [message #905480 is a reply to message #904363] Thu, 30 August 2012 09:05 Go to previous messageGo to next message
I am setting them via the code fragments:
public Timestamp getTimestamp(int index) throws OdaException {
try {
//retured as sql since this is what this class is required to return to BIRT
return new java.sql.Timestamp(time.parse(sourceData.get(m_currentRowId - 1).get(index - 1)).getTime());
} catch (ParseException e) {
e.printStackTrace();
return null;
and
public int getColumnType(int index) throws OdaException {
String columnName = sourceData.get(0).get(index - 1);
if (columnName.equalsIgnoreCase("DocID") || columnName.equalsIgnoreCase("ShardID")) {
return java.sql.Types.INTEGER;
if (columnName.equalsIgnoreCase("ImportID")) {
return java.sql.Types.BIGINT;
if (columnName.equalsIgnoreCase("Score")) {
return java.sql.Types.DOUBLE;
if (columnName.equalsIgnoreCase("Date")) {
return java.sql.Types.TIMESTAMP;
else {
return java.sql.Types.CHAR;
It is showing up as date time in the output column window of the data set, so it seems as though it is set properly...
Re: Problem charting datetime [message #905598 is a reply to message #905480] Thu, 30 August 2012 13:56 Go to previous messageGo to next message
James
I am not sure what is happening with this. In one oda I worked on I
stored all dates as Java date millis using get time and when I need to
convert I did:
public Timestamp getTimestamp( int index ) throws OdaException
try{
return new Timestamp(Long.parseLong( getString( index ) ));
}catch (Exception e){
return null;
Did you try storing the dates in a csv file. Then create the report
off the csv. I would like you to try this to verify you get the same
results as I did.
Jason
> try {
> to return to BIRT
> return new
> return null;
> and
> } if (columnName.equalsIgnoreCase("Date")) {
> else {
Re: Problem charting datetime [message #905861 is a reply to message #905598] Fri, 31 August 2012 04:06 Go to previous messageGo to next message
It still happens when I use the .csv datetime column(see attched) but not when I use the date column (the same as what happens with my oda). So this seems to suggest it isn't a preoblem with my oda.
What in BIRT could be causing this?
James
[Updated on: Fri, 31 August 2012 04:07] by Moderator
Re: Problem charting datetime [message #905935 is a reply to message #905861] Fri, 31 August 2012 06:35 Go to previous messageGo to next message
I just tried this with a fresh install of eclipse and BIRT and still have the same problem..
Re: Problem charting datetime [message #906108 is a reply to message #905935] Fri, 31 August 2012 12:26 Go to previous messageGo to next message
Can you send me a report with the csv that shows the issue?
Jason
Re: Problem charting datetime [message #907048 is a reply to message #904363] Mon, 03 September 2012 04:03 Go to previous messageGo to next message
Hi, I have included my .csv too.
James
Re: Problem charting datetime [message #908020 is a reply to message #907048] Tue, 04 September 2012 10:50 Go to previous messageGo to next message
James
For some reason I can not read the report. Can you zip it an the data
and email to me at jasonweathersby at windstream dot net?
Jason
> James
Re: Problem charting datetime [message #908066 is a reply to message #908020] Tue, 04 September 2012 12:31 Go to previous messageGo to next message
sent, thanks for the help
Re: Problem charting datetime [message #908075 is a reply to message #908066] Tue, 04 September 2012 12:46 Go to previous message
James
I did not get the email?
Jason
Previous Topic:Applet jar requirements for BIRT (4.2) ReportEngine
Next Topic:[chart]Mixing stacked and unstacked bars
Current Time: Sat Nov 08 18:39:35 EST 2025
Powered by FUDForum. Page generated in 0.05424 seconds
