Home » Eclipse Projects » EclipseLink » Anyone using EclipseLink-EIS(need it to support mapping Java POJOs onto non-relational data stores)
Anyone using EclipseLink-EIS [message #900241] Mon, 06 August 2012 01:37 Go to next message
I have a requirement to support mapping Java POJOs onto non-relational data stores using the Java Connector Architecture (JCA) API. From its description, EclipseLink-EIS seems what I am looking for.
On following URL: http://www.eclipse.org/eclipselink/ I only see JPA, MOXy & DBWS. I see no reference to EclipseLink-EIS. I am still unsure about the implementation status of this project.
Could you please help me understand if EclipseLink-EIS is ready for use or what stage it is in? Anyone has got any experience with it?
I'd appreciate your help.
Praveen
Re: Anyone using EclipseLink-EIS [message #900780 is a reply to message #900241] Wed, 08 August 2012 09:08 Go to previous messageGo to next message
EclipseLink's EIS support has been renamed EclipseLink NoSQL in 2.4,
see
http://wiki.eclipse.org/EclipseLink/FAQ/NoSQL
http://wiki.eclipse.org/EclipseLink/UserGuide/JPA/Advanced_JPA_Development/NoSQL
EclipseLink NoSQL is ready for use and under active development.
What EIS system do you need to access?
Re: Anyone using EclipseLink-EIS [message #901002 is a reply to message #900780] Thu, 09 August 2012 07:36 Go to previous messageGo to next message
Thanks James. I'd investigate EclipseLink NoSQL further.
Regarding your question on what EIS I am trying to connect. There are some in-house products who have got proprietary API to access the data. My assumption is that by doing some extensions to EclipseLink NoSQL, it will allow me to accomplish it. Am I right?
Re: Anyone using EclipseLink-EIS [message #905040 is a reply to message #901002] Wed, 29 August 2012 11:28 Go to previous message
Yes, you will need to write your own JCA adapter and an EISPlatform for your data-source.
The easiest way to do this would be to copy one of the existing ones provided in EclipseLink and customize it for your data-sources API.
Previous Topic:Can not set ManyToOne field to inherited entity
Next Topic:setTableQualifier(schema) without transaction
Current Time: Wed Jul 23 15:24:53 EDT 2025
Powered by FUDForum. Page generated in 0.03554 seconds
