Home » General (non-technical) » Project Proposals » Autocorrect - the apple way(instant autocorrect)
Autocorrect - the apple way [message #904983] Wed, 29 August 2012 10:10 Go to next message
When typing java code, the eclipse autocorrect currently suggests quick fixes. However, this is still tedious since you have to hover your mouse over the exception, or use shortcuts.
However, when trivial fixes are available (with typo's, e.g. privtae -> private, or Strign -> String), eclipse should autocorrect without warning (or by quickly underlining the keyword for a short period). This would help the development alot!
Re: Autocorrect - the apple way [message #905273 is a reply to message #904983] Wed, 29 August 2012 23:56 Go to previous messageGo to next message
This is an interesting idea. However, this isn't the right forum (I can
understand how the name "proposals" might be a bit misleading).
The best way to make this sort of recommendation is to open a bug
against Eclipse/Platform [1]. Or you can make the suggestion in the
eclipse.platform forum [2].
HTH,
Wayne
[1] https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform
[2] http://www.eclipse.org/forums/eclipse.platform
> over the exception, or use shortcuts. However, when trivial fixes are
Re: Autocorrect - the apple way [message #906237 is a reply to message #905273] Fri, 31 August 2012 18:56 Go to previous messageGo to next message
thanks for your response, I will post it on the mentioned platforms.
Re: Autocorrect - the apple way [message #913333 is a reply to message #905273] Sat, 15 September 2012 05:33 Go to previous messageGo to next message
Wayne Beaton wrote on Thu, 30 August 2012 05:56
I think we should rename this forum to "Project Proposals".
Re: Autocorrect - the apple way [message #948169 is a reply to message #913333] Wed, 17 October 2012 16:35 Go to previous message
Sopot Cela wrote on Sat, 15 September 2012 11:33
+1
Previous Topic:Show project by window
Next Topic:Minimal Mode for Dialog Boxes
Current Time: Sun Jul 27 11:14:09 EDT 2025
Powered by FUDForum. Page generated in 0.03773 seconds
