Home » Archived » Lua Development Tools » Code Formatter, Code Assistance and Outline do not work(Some problems)
Code Formatter, Code Assistance and Outline do not work [message #903865] |
Sun, 26 August 2012 18:17  |
I tried to use the features Code Formatter, Code Assistance and Outline, but I can not se anyone of these working.
I just scrambled Code and the Ctrl+Shift+F does nothing. I included the environment (and added it to the execution environments) but the Code Assistance did not show up (only @ Koneki distribution. @ Juno + plugin it works nearby nice).
The Outline doesn't work. At the Koneki distribution of Eclipse nothing shows up. on the Juno + plugin version it just shows local variables and functions.
I searched via google and the forum search and I read some tutorials but nothing says anything about this problem. I think i missed something (I had to have missed something). Any help out there? Just a link to another Thread or anything would be helpfull -.-
Re: Code Formatter, Code Assistance and Outline do not work [message #904842 is a reply to message #903906] |
Wed, 29 August 2012 05:00   |
Hi Benedikt,
First, please check if your code is located in a Lua Project.
If it's the case and you still have the bug, we doesn't have enough data to find your problem, and we can't reproduce.
So, please, can you redroduce your bugs in a fresh sandalone LDT version.
Then copy/paste the full version number you can find in the "Help/About" menu and also attach your log files to your response
Log files can be found in : <workspace folder>/.metadata/*.log
If anyone else reproduce the bug, it will be helpful to send us your log and version too.
Marc
Re: Code Formatter, Code Assistance and Outline do not work [message #904909 is a reply to message #904842] |
Wed, 29 August 2012 07:16   |
Hello again,
Thanks for reminding me that there is a logfile... I found the half of the bug: I am using a "invisible" folder. Its name has only one char. The value of the char is 255. Java never gets that the charvalue 255 is valid in a execution-path. because of this Koneki didnt find the necessary files and only loaded stuff it where the paths starts with "./" (or ".\"),
but still, it only shows local variables (and does not asign types to variables)
but here is the stuff:
0.8:
Eclipse Platform 3.7.2.v20120207-1839-9gF7UHPDFxGjd-PqDr2jX_4yKaumkoHTz04_q-q
Eclipse Modeling Framework Core Runtime 2.7.1.v20120127-1122
Lua Development Tools 0.8.1.201207111957
m0.9:
Eclipse Plattform 4.2.0.v20120608-135145-9JF7BHV8FyMteji0Oi_ePMz0xuZ8TVo7lV0z0ecb
Eclipse Modeling Framework Core Runtime 2.8.0.v20120606-0717
Lua Development Tools 0.9.0.201208231337
!SESSION 2012-08-29 13:05:56.332 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.7.0_04
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_DE
Command-line arguments: -os win32 -ws win32 -arch x86_64
!ENTRY org.eclipse.ui 4 4 2012-08-29 13:06:02.638
!MESSAGE Unable to find Action Set: org.eclipse.mylyn.context.ui.actionSet
!ENTRY org.eclipse.ui 4 4 2012-08-29 13:06:02.641
!MESSAGE Unable to find Action Set: org.eclipse.mylyn.doc.actionSet
!ENTRY org.eclipse.ui 4 4 2012-08-29 13:06:02.642
!MESSAGE Unable to find Action Set: org.eclipse.mylyn.tasks.ui.navigation
!MESSAGE Unable to find Action Set: org.eclipse.rse.core.search.searchActionSet
!ENTRY org.eclipse.koneki.ldt 4 0 2012-08-29 13:06:02.729
!MESSAGE Unable to load metalua ast builder :/testProject/src/main.lua
!STACK 0
com.naef.jnlua.LuaRuntimeException: requireContentFromPath:1: module 'metalua.compiler' not found:
no field package.preload['metalua.compiler']
no file 'C:\Users\tDwtp\Desktop\ \4nd\python ideas\lua\ecl\koneki eclipse m0.9\configuration\org.eclipse.osgi\bundles\172\2\.cp\lib\metalua\compiler.luac'
no file 'C:\Users\tDwtp\Desktop\ \4nd\python ideas\lua\ecl\koneki eclipse m0.9\configuration\org.eclipse.osgi\bundles\172\2\.cp\lib\metalua\compiler.lua'
at com.naef.jnlua.LuaState.lua_pcall(Native Method)
at com.naef.jnlua.LuaState.call(LuaState.java:555)
at org.eclipse.koneki.ldt.metalua.internal.MetaluaStateFactory.newLuaState(MetaluaStateFactory.java:73)
at org.eclipse.koneki.ldt.metalua.AbstractMetaLuaModule.compileMetaluaFiles(AbstractMetaLuaModule.java:35)
at org.eclipse.koneki.ldt.metalua.AbstractMetaLuaModule.loadLuaModule(AbstractMetaLuaModule.java:30)
at org.eclipse.koneki.ldt.core.internal.ast.parser.ModelsBuilderLuaModule.buildAST(ModelsBuilderLuaModule.java:43)
at org.eclipse.koneki.ldt.core.internal.ast.parser.LuaSourceParser.parse(LuaSourceParser.java:106)
at org.eclipse.dltk.core.SourceParserUtil.parse(SourceParserUtil.java:137)
at org.eclipse.dltk.core.SourceParserUtil.getModuleDeclaration(SourceParserUtil.java:197)
at org.eclipse.dltk.core.SourceParserUtil.getModuleDeclaration(SourceParserUtil.java:183)
at org.eclipse.dltk.core.SourceParserUtil.getModuleDeclaration(SourceParserUtil.java:174)
at org.eclipse.dltk.core.AbstractSourceElementParser.parse(AbstractSourceElementParser.java:42)
at org.eclipse.dltk.core.AbstractSourceElementParser.parseSourceModule(AbstractSourceElementParser.java:26)
at org.eclipse.dltk.internal.core.structure.StructureIndexer.indexDocument(StructureIndexer.java:139)
at org.eclipse.dltk.internal.core.structure.StructureProjectIndexer.doIndexing(StructureProjectIndexer.java:20)
at org.eclipse.dltk.core.search.indexing.core.AbstractProjectIndexer.indexSourceModule(AbstractProjectIndexer.java:155)
at org.eclipse.dltk.core.search.indexing.core.SourceModulesRequest.run(SourceModulesRequest.java:90)
at org.eclipse.dltk.core.search.indexing.AbstractJob.execute(AbstractJob.java:76)
at org.eclipse.dltk.internal.core.search.processing.JobManager.run(JobManager.java:467)
!SESSION 2012-08-29 13:08:07.643 -----------------------------------------------
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2012-08-29 13:08:14.729
!MESSAGE No repository found at file:/C:/Users/tDwtp/Desktop/%C2%A0/4nd/python%20ideas/lua/ecl/koneki%20eclipse%20m0.9/.eclipseextension.
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2012-08-29 13:08:14.738
!MESSAGE No repository found at file:/C:/Users/tDwtp/Desktop/%C2%A0/4nd/python%20ideas/lua/ecl/koneki%20eclipse%20m0.9/configuration/org.eclipse.osgi/bundles/131/data/listener_1925729951/.
!ENTRY org.eclipse.ui 4 4 2012-08-29 13:08:15.289
!ENTRY org.eclipse.ui 4 4 2012-08-29 13:08:15.290
!ENTRY org.eclipse.ui 4 4 2012-08-29 13:08:15.291
!ENTRY org.eclipse.koneki.ldt.ui 2 0 2012-08-29 13:08:17.128
!MESSAGE org.eclipse.koneki.ldt.core.internal.ast.models.file.Identifier starting at offset 109 with length 4 has no definition.
!ENTRY org.eclipse.jface 2 0 2012-08-29 13:08:34.138
!MESSAGE Keybinding conflicts occurred. They may interfere with normal accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2012-08-29 13:08:34.138
!MESSAGE A conflict occurred for ALT+SHIFT+T:
Binding(ALT+SHIFT+T,
ParameterizedCommand(Command(org.eclipse.dltk.ui.edit.text.script.refactor.quickMenu,Show Refactor Quick Menu,
Shows the refactor quick menu,
Category(org.eclipse.dltk.ui.category.refactoring,Refactor - DLTK,DLTK Refactoring Actions,true),
org.eclipse.ui.internal.MakeHandlersGo@284d3adf,
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.dltk.ui.scriptEditorScope,,,system)
,,true),null),
org.eclipse.dltk.ui.context.views,,,system)
!MESSAGE A conflict occurred for ALT+SHIFT+R:
Binding(ALT+SHIFT+R,
ParameterizedCommand(Command(org.eclipse.dltk.ui.edit.text.script.rename.element,Rename - Refactoring ,
Rename the selected element,
org.eclipse.ui.internal.MakeHandlersGo@66541b24,
,,true),null),
,,true),null),
Benedikt
P.S.: Sorry -.-
P.P.S.: Is there a possibility to get it showing all variables and asigning variables to types so I can call :flush() not only on io.{stdin|stdout|stderr}
Re: Code Formatter, Code Assistance and Outline do not work [message #904922 is a reply to message #904919] |
Wed, 29 August 2012 07:40  |
Benedikt Roland wrote on Wed, 29 August 2012 13:31Again, sorry. It asigns #types at variables, but only if they are local... that should have a fix! Doesn't it?
You should have a look at http://www.eclipse.org/forums/index.php/mv/msg/351391/871406/#msg_871406 and several other threads on the forum. The thing with global variable it that it is difficult to know whether or not they are available at a given location in the code, thus it is virtually impossible to know what to propose when one hits CTRL+SPACE on a new empty line (that would be a bad idea to clutter the content-assist with *ALL* the global variables found in the current project and its dependencies, right?)
Something other: I cannot uncollapse functions in the outline. Is that even possible? thats something major in the outline...
Can you provide a screenshot? Not sure what you mean by "uncollapsing functions" since they are not foldable in the first place (i.e. they are leaves in the tree, no?)
Anyways, thanks much for taking time to give feedback!
Benjamin.
Current Time: Sat Jul 19 03:50:29 EDT 2025
Powered by FUDForum. Page generated in 1.06778 seconds
