Home » Eclipse Projects » Eclipse 4 » take advantage of e4 ContextFunction(compute() method didn't get called)
take advantage of e4 ContextFunction [message #904724] Tue, 28 August 2012 23:09 Go to next message
I was learning e4 ContextFunction to implement a diagram editor in a similar way that SimpleIDE does for text editor, binding its DocumentInput implementation to the interface.
Here's my practice.
1. created an interface named DiagramInput that extends a third party interface (org.eclipse.graphiti.ui.editor.IDiagramEditorInput)
2. created class DiagramInputProviderFunction that extends org.eclipse.e4.core.contexts.ContextFunction. put debug info in compute(IEclipseContext context).
3. created a component definition file as below
<scr:component xmlns:scr="http://www.osgi.org/xmlns/scr/v1.1.0" name="com.xxx.editor.diagram.common.ui">
   <implementation class="com.xxx.editor.diagram.common.ui.services.DiagramInputProviderFunction"/>
   <property name="service.context.key" type="String" value="com.xxx.editor.diagram.common.ui.DiagramInput"/>
   <service>
      <provide interface="org.eclipse.e4.core.contexts.IContextFunction"/>
   </service>
</scr:component>
4. created a diagram editor class that expects to consume DiagramInput in constructor.
@Inject
    public DialogDiagramEditor(Composite parent, DiagramInput input) {
        System.out.println("DialogDiagramEditor constructor satisfied.");
I thought when e4 tries to do the di for DiagramInput to satisfy the constructor of DialogDiagramEditor. It can read component definition file and call the compute() in my DiagramInputProviderFunction. However, debugging tells that compute() didn't get called.
What am I missing here? I don't think I need to set DiagramInput to ContextFunction in code...
Johnny
[Updated on: Tue, 28 August 2012 23:11] by Moderator
Re: take advantage of e4 ContextFunction [message #904728 is a reply to message #904724] Tue, 28 August 2012 23:22 Go to previous messageGo to next message
Is the bundle you have the DS-Component defined in marked as lazy - this
is required if you want the DS-Extender to pick up your bundle.
Tom
Am 29.08.12 05:10, schrieb Johnny Qin:
> Here's my practice.
> name="com.voxware.designer.editor.diagram.common.ui">
> <implementation
> class="com.voxware.designer.editor.diagram.common.ui.services.DiagramInputProviderFunction"/>
> value="com.voxware.designer.editor.diagram.common.ui.DiagramInput"/>
> <service>
> </service>
> </scr:component>
> in constructor.
> @Inject
> Johnny
Re: take advantage of e4 ContextFunction [message #904738 is a reply to message #904728] Wed, 29 August 2012 00:10 Go to previous message
Thanks Tom! your suggestion works, of course Smile
Johnny
Thomas Schindl wrote on Tue, 28 August 2012 23:22
Tom
> Here's my practice.
> <implementation
> <service>
> </service>
> </scr:component>
> in constructor.
> @Inject
> Johnny
Previous Topic:Focusing windows
Next Topic:E4/GWT integration
Current Time: Sat Jul 19 01:16:03 EDT 2025
Powered by FUDForum. Page generated in 0.03015 seconds
