Home » Modeling » M2T (model-to-text transformation) » [Acceleo] select over a Set(String) object
[Acceleo] select over a Set(String) object [message #904500] Tue, 28 August 2012 10:42 Go to next message
How may I execute a select over an set of String?
I mean setOfString->select(='test') is wrong, also setOfString->select(self='test')
what is the right syntax?
Re: [Acceleo] select over a Set(String) object [message #904507 is a reply to message #904500] Tue, 28 August 2012 10:54 Go to previous messageGo to next message
Have you tried defining an iterator variable and using it?
Ed Willink
Re: [Acceleo] select over a Set(String) object [message #904517 is a reply to message #904500] Tue, 28 August 2012 11:25 Go to previous messageGo to next message
My aim is not to iterate over the set. I need to do something only if a string (say 'test') is contained in the set. If the set does not contain that string I need to do something else.
i.e.
[if setOfString->select(??='test')->notEmpty()]
generate something
[else]
generate something else
[/if]
How would you do that by means of an iterator?
Re: [Acceleo] select over a Set(String) object [message #904545 is a reply to message #904517] Tue, 28 August 2012 12:46 Go to previous messageGo to next message
setOfString->exists(s : String | s = 'test')
setOfString->includes('test')
Ed Willink
> i.e.
> generate something
> [else]
> [/if]
Re: [Acceleo] select over a Set(String) object [message #904558 is a reply to message #904500] Tue, 28 August 2012 13:20 Go to previous messageGo to next message
Thank you Ed I did not know that syntax
Andrea
Re: [Acceleo] select over a Set(String) object [message #904802 is a reply to message #904558] Wed, 29 August 2012 03:24 Go to previous message
Andrea,
Ed's answer is right, I'll just add that you can also use iterators in select and reject operations with the same syntax he has outlined for "exists" :
[setOfString->select(s : String | s = 'test')]
i.e :
variable.operation(iterator | body)
. This same syntax exists for all 'iteration' operation : select, reject, collect, exists, forAll, isUnique, one, any and sortedBy.
Though of course, "includes" is better if you only need to check whether you set contains a given value.
Laurent Goubet
Obeo
Previous Topic:[Acceleo] select distinct
Next Topic:Acceleo induced InvalidRegistryObjectException
Current Time: Fri Jul 18 23:56:12 EDT 2025
Powered by FUDForum. Page generated in 0.22070 seconds
