Home » Modeling » QVT-OML » How to manually register blackbox units?
How to manually register blackbox units? [message #904464] Tue, 28 August 2012 09:19 Go to next message
I want to use java blackbox units. However, I'm using QVTo not within
Eclipse, but withing an EJB Java Application. So I can't use the
org.eclipse.m2m.qvt.oml.javaBlackboxUnits extension point.
I found the BlackboxRegistry class, but I saw this very discouraging
piece of code:
private BlackboxRegistry() {
try {
if(EMFPlugin.IS_ECLIPSE_RUNNING) {
fProviders = Eclipse.readProviders();
} else {
fProviders = Collections.emptyList();
} catch (RuntimeException e) {
QvtPlugin.error(e);
Usages of BlackboxRegistry.INSTANCE also seem not to allow me to
intercept this in any way.
Hopefully I have missed something important, any hints greatly appreciated!
Marius
Re: How to manually register blackbox units? [message #904611 is a reply to message #904464] Tue, 28 August 2012 16:19 Go to previous messageGo to next message
The code seems to be unhelpful. Although most of BlackboxRegistry is
public, the private constructor seems to prevent
you enhancing it.
The EMF extension points use extensions as just one way of populating a
registry. Unfortunately the BlackboxRegistry does
not follow this idiom. If you care to submit a patch emulating EMF
registries, it should solve your problems and be available
for others.
Please submit a Bugzilla anyway.
Ed Willink
On 28/08/2012 14:19, Marius Gröger wrote:
> Hello,
> piece of code:
> try {
> } else {
> QvtPlugin.error(e);
> Marius
Re: How to manually register blackbox units? [message #904816 is a reply to message #904611] Wed, 29 August 2012 03:49 Go to previous messageGo to next message
> a registry. Unfortunately the BlackboxRegistry does not follow this
> idiom. If you care to submit a patch emulating EMF registries, it
> should solve your problems and be available for others.
I needed Blackboxes just to tell QVT how to create a few custom types. I
was able to get rid of those types so I now only use plain Ecore types,
and my need for Blackboxes has gone. Should I need them again in the
future, I will attempt to fix this. Glancing over the EP processing code
I noticed that a great many internal data types are used there. To
properly allow manual registering of a (Java)BlackboxProvider, some
refactoring will be required I guess.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=388293
Marius
Re: How to manually register blackbox units? [message #922973 is a reply to message #904816] Tue, 25 September 2012 09:55 Go to previous messageGo to next message
I developed that patch by modifying the JavaBlackboxRegistry and JavaBlackboxProvider classes in org.eclipse.m2m.qvt.oml. The blackbox libraries are now searched in the whole classpath.
This patch works and it's actually deployed on our online modeler at www.genmymodel.com .
Would you be interested by this patch ? Where should I submit it ?
Tom
Re: How to manually register blackbox units? [message #923105 is a reply to message #922973] Tue, 25 September 2012 11:51 Go to previous messageGo to next message
Any patch should be submitted as a patch attached to a Bugzilla. For a
couple of hundred lines it may be sufficient to state that you are the
sole author and consent to the code being made available under EPL.
For larger contributions, the above process will need to be followed up
to ensure written consent from your employer.
The QVTo team has very limited resources, so to facilitate adoption
please provide one or more JUnit tests that fail until the new code is
included.
Ed Willink
On 25/09/2012 14:55, thomas legrand wrote:
> Tom
Re: How to manually register blackbox units? [message #945689 is a reply to message #922973] Mon, 15 October 2012 10:36 Go to previous message
On 25.09.2012 15:55, thomas legrand wrote:
> Tom
Hello Thomas,
sorry for the late response - I would indeed be interested in this
patch. Can you append it to this ticked as a partial solution:
Marius
Previous Topic:Possibility to generate Circular Referenced target model
Next Topic:[QVTo] trace model and proxies
Current Time: Sat Jul 19 00:44:00 EDT 2025
Powered by FUDForum. Page generated in 0.04936 seconds
