Home » Modeling » EMF » Programatically select Item in Editor in different window
Programatically select Item in Editor in different window [message #904360] Tue, 28 August 2012 06:10 Go to next message
Hi everyone,
I'm afraid I need some help again. What I want to do is the following:
I am keeping a relation URI from elements in my model to elements in a different resource. I want to add a functionality to trace down that other element, open it in another editor (might already be opened), extend the tree as far as needed to select that element in the other viewer.
I have already gotten as far that I can check if that other file is already open by checking the titles of the editor's parts against a part of my URI. I can open the resource, iterate through it and look for my item that I can also find. I can focus the editor on my other model. Now I want to select the item I have found in the editor that already opened the resource I want.
My appreach was the follwing:
List<Item> selectionList = new LinkedList<Item>();
selectionList.add(findItem(itemURI));
editor.setSelection(new StructuredSelection(selectionList));
That doesn't seem to do the trick.
I have access to the editor, the IEditorPart , the resource and the item. So to me it seems I have all the ingredients together.. Smile
Any help would be great!
Thanks, Markus
Re: Programatically select Item in Editor in different window [message #904369 is a reply to message #904360] Tue, 28 August 2012 06:27 Go to previous messageGo to next message
Markus,
Comments below.
On 28/08/2012 12:10 PM, Markus G wrote:
> Hi everyone,
> viewer.
I think you can just ask for the editor to be opened like what we do in
org.eclipse.emf.edit.ui.util.EditUIUtil.openEditor(EObject)
No, that sets what the editor normally updates itself based on
selections in the viewer.
> item. So to me it seems I have all the ingredients together.. :)
You need to call the setSelectionToViewer method to actually update the
selection in the active view within the editor.
> Thanks, Markus
Re: Programatically select Item in Editor in different window [message #904427 is a reply to message #904369] Tue, 28 August 2012 08:14 Go to previous messageGo to next message
Hi Ed,
thanks a lot for the reply. The EditUIUtil.openEditor() is much nicer than the way I had implemented it before.
So now opening the editor is working well. But extending the tree view and selecting my element is still now working properly.
I tried your suggestion
List<Element> selectionList = new LinkedList<Element>();
selectionList.add(searchedForElement);
editor.setSelectionToViewer(selectionList);
and also, because it seemed promising:
editor.getViewer().setSelection(new StructuredSelection(searchedForElement), true);
But both don't change the viewer.
Do you have another idea how I could select that item?
[Updated on: Tue, 28 August 2012 08:15] by Moderator
Re: Programatically select Item in Editor in different window [message #904435 is a reply to message #904427] Tue, 28 August 2012 08:26 Go to previous messageGo to next message
Markus,
Is searchedForParam really an EObject contained in a resource contained
by that editor's resource set? Do your item providers require any
wrapping in which case you have to find the wrapper using something like
AdapterFactoryEditingDomain.getWrapper to get the object that should be
selected. Note that if you debug through that method, it better not get
to the very last return, because in that case your object isn't really
in the tree...
On 28/08/2012 2:14 PM, Markus G wrote:
> Hi Ed,
> List<AbstractParameter> selectionList = new
> LinkedList<AbstractParameter>();
> StructuredSelection(searchedForParam), true);
Re: Programatically select Item in Editor in different window [message #904443 is a reply to message #904435] Tue, 28 August 2012 08:35 Go to previous messageGo to next message
Hi Ed,
I'm pretty sure that searchedForElement is contained in a resource.
EditUIUtil.openEditor(searchedForElement)
also opens the editor correctly, so that should already prove that the element is present and contained in a resource contained by that editor's resource set, right?
Doesn't that also mean that it's definitly in the tree? Otherwise the openEditor call would fail, no?
I did not explicitly add anything connected to wrappers in my ItemProviders. What exactly would that mean?
Can I simply put that one element into a LinkedList and give it to the editor, though? Maybe that's the problem..?
Thanks!
[Updated on: Tue, 28 August 2012 08:37] by Moderator
Re: Programatically select Item in Editor in different window [message #904466 is a reply to message #904443] Tue, 28 August 2012 09:22 Go to previous messageGo to next message
Markus,
Comments below.
On 28/08/2012 2:35 PM, Markus G wrote:
> Hi Ed,
Yes, a resource, but if you look at what that utility does, it
determines the URI of the containing resource and opens an editor for
that URI. That editor will have its own copy of the resource and its
contained objects object, not the same instance you started with. You
need to get the instance in that editor.
> also opens the editor correctly, so that should already proves that
No.
No. Unless you did something to locate the object actually created by
the editor, you won't have the right object. EcoreUtil.getURI will
create a URI for your object. ResourceSet.getEObject can resolve that
URI in the resource set of the editor you've opened.
Given you've not really provided much detail, there's no point in me
explaining complex things that might not even apply.
> Thanks!
Re: Programatically select Item in Editor in different window [message #905347 is a reply to message #904466] Thu, 30 August 2012 04:00 Go to previous messageGo to next message
Hi Ed,
thanks. Yes, you're right, but the wrapping most probably isn't my problem, so you're right, there's no point in you wasting effort to explain that complex topic here.
My problem was that I didn't see that opening a new editor opens a new instance of my resource..
So, after opening the new editor, can I access my model's root element? Then I could simply use my find function again to locate the element I'm looking for and select it then.
Thanks!
Re: Programatically select Item in Editor in different window [message #905372 is a reply to message #905347] Thu, 30 August 2012 05:00 Go to previous message
Hi Ed,
never mdin my last post, I figured it out myself.
Once again thanks a lot for your support!!
Previous Topic:[CDO] Finding detached objects
Next Topic:XSDEcoreBuilder, Validation
Current Time: Fri Jul 25 06:19:30 EDT 2025
Powered by FUDForum. Page generated in 0.26395 seconds
