LDAP roles as parameters to scripts [message #902805] |
Mon, 20 August 2012 10:15  |
I'm using hudson v2.2.0 as a tool for build and deploy. Currently the authentication/authorisation is controlled by hudson's internal user-database. This has to change : LDAP has to be used for this in the future.
Some procedures (shell-scripts) use the HUDSON_USER environment variable to control parts of the flow (a bit wacky, I know). The fastest way to 'transform' the processes is to use the LDAP-roles for the same purpose (or is it?).
Question: how do I get the scripts to identify which role (or roles) the user has?
The LDAP authentication can control hudson, can information resulting from that be passed on to shell-scripts that are run by the hudson-jobs?
FUDForum. Page generated in 0.06740 seconds
