Home » Language IDEs » ServerTools (WTP) » Faceted Project Problem: Target runtime jre7 is not defined.
Faceted Project Problem: Target runtime jre7 is not defined. [message #903943] Mon, 27 August 2012 07:38 Go to next message
I got a error icon on one of our projects. The Problem-View shows "Faceted Project Problem: Target runtime jre7 is not defined.".
How can i solve the problem ? JRE7 is configured for my workspace, so i have no clue what the problem is.
Thanks!
Re: Faceted Project Problem: Target runtime jre7 is not defined. [message #904023 is a reply to message #903943] Mon, 27 August 2012 11:22 Go to previous messageGo to next message
Have you tried to go to the project's property page called Targeted runtimes? There you can see the current target runtime, and if you select "Show all runtimes" you can see all the runtimes installed in your workspace.
Re: Faceted Project Problem: Target runtime jre7 is not defined. [message #904439 is a reply to message #904023] Tue, 28 August 2012 08:30 Go to previous messageGo to next message
The build path was set to JDK6, now i changed it to workspace default JDK7 (Project Properties|Java Build Path| Libraries|Edit|Workspace Default), but the problem remains.
Btw. my project got no property page called "Targeted runtimes" (maybe because it's an Plugin-Project?).
http://www.eclipse.org/forums/index.php/fa/11313/0/
Re: Faceted Project Problem: Target runtime jre7 is not defined. [message #974955 is a reply to message #904439] Wed, 07 November 2012 08:24 Go to previous message
For the record:
The Problem can be fixed, by deleting <project>/.settings/org.eclipse.wst.common.facet.core.xml, and clicking on "Update classpath setting" in the manifest editor. Et-Voila no compile-errors!
Previous Topic:How to have a tomcat server added that is already running/started outside of eclipse?
Next Topic:Exporting static web project
Current Time: Sat Jul 19 01:40:31 EDT 2025
Powered by FUDForum. Page generated in 0.16863 seconds
