Home » Eclipse Projects » Rich Client Platform (RCP) » Opening an editor
Opening an editor [message #901437] Sun, 12 August 2012 07:15 Go to next message
Hi all!
I have (very) recently started to play with the e4 applications but I am stuck with the editors.
To open an editor, as suggested in the vogella.com articles, you should use the getViewSite() method if you are in a view, but in my application it is always null.
To recreate this scenario, you can create an application using the "Eclipse 4 Application Project" wizard and add a simple view to the project.
As far as I guess, this happens because the init() method is never or badly called. What am I missing? Should I explicitly call the init() method somewhere?
Thanks in advance, Daniele
Re: Opening an editor [message #901438 is a reply to message #901437] Sun, 12 August 2012 07:17 Go to previous messageGo to next message
Pure e4 does NOT support editors! You need to run with the compat layer.
I plan to work on pure e4 editors in autumn.
Tom
Am 12.08.12 13:15, schrieb Daniele Canavese:
> Hi all!
> it is always null.
> project.
> method somewhere?
Re: Opening an editor [message #901439 is a reply to message #901438] Sun, 12 August 2012 07:25 Go to previous messageGo to next message
Thanks for the quick reply!
Daniele
Re: Opening an editor [message #903607 is a reply to message #901438] Fri, 24 August 2012 09:57 Go to previous messageGo to next message
Hello Tom,
There are plain text editor and xml editor in simpleIDE. I thought they are pure e4 editors...
Johnny
Thomas Schindl wrote on Sun, 12 August 2012 07:17
Tom
> Hi all!
> it is always null.
> project.
> method somewhere?
Re: Opening an editor [message #903680 is a reply to message #903607] Fri, 24 August 2012 17:03 Go to previous messageGo to next message
Right simple-IDE has our first explorations on how implement native e4
editors. I expect to start work on this in about 1-2 months so that
native editor support is available in 4.3.
Tom
Am 24.08.12 15:57, schrieb Johnny Qin:
> Hello Tom,
> Best regards,
> Johnny
>> Tom
>> > Hi all!
>> but I am
>> should
>> application
>> > it is always null.
>> > project.
>> > method somewhere?
Re: Opening an editor [message #903969 is a reply to message #903680] Mon, 27 August 2012 09:16 Go to previous message
I see. Thanks Tom.
Thomas Schindl wrote on Fri, 24 August 2012 17:03
Tom
> Hello Tom,
> Best regards,
> Johnny
>> Tom
>> > Hi all!
>> but I am
>> should
>> application
>> > it is always null.
>> > project.
>> > method somewhere?
Previous Topic:Is there a UI to register xmlns:myownmodel to extend e4 application model
Next Topic:java.lang.RuntimeException: No application id has been found.
Current Time: Sat Jul 26 13:20:50 EDT 2025
Powered by FUDForum. Page generated in 0.05986 seconds
