Home » Archived » Hudson » hudson and .svn
hudson and .svn [message #903731] Sat, 25 August 2012 04:05 Go to next message
Hi all.
I have found one moment, that is very strange for me. When I update svn repository manually, .svn folder has next structure:
/prop-base
/props
/text-base
/tmp
all-wcprops
dir-prop-base
entries
but when hudson update before building, it .svn has other structure:
/pristine
/tmp
entries
format
wc.db
And these differents cause problem during my building =(
Why it so? How I can get .svn structure which created by hudson similar to .svn structure which created manually?
Thanks.
Re: hudson and .svn [message #903733 is a reply to message #903731] Sat, 25 August 2012 04:11 Go to previous messageGo to next message
The svn update you are doing manually is being done on an older version of svn, probably 1.6. Hudson uses svn 1.7 by default which is said to have some major speed improvements.
The tree structure for svn 1.6 is to put a .svn folder in each individual folder, where svn 1.7 puts the .svn folder in the root location which is why you are seeing less.
To validate my theory, run "svn --version" via command line and make sure to update to the latest version, either that or go into manage hudson > configure system and change the workspace version to 1.6(svn:external to file).
Re: hudson and .svn [message #903734 is a reply to message #903733] Sat, 25 August 2012 04:25 Go to previous messageGo to next message
I don't know why, but I can't set in hudson > configure system svn 1.7 at all(hudson version 2.2.1) and there is set 1.6(svn:external to file).
"svn --version" in hudson build step returns: svn, version 1.6.17 (r1128011)
My client has 1.6.17 too and because differents in .svn structures are puzzle for me...
[Updated on: Sat, 25 August 2012 04:27] by Moderator
Re: hudson and .svn [message #903736 is a reply to message #903734] Sat, 25 August 2012 05:38 Go to previous messageGo to next message
What version of the svn plugin are you using? I believe you are using an older version. I accidentally released a version with svn 1.7, but forgot to put that as an option. Make sure version 2.3.3 is installed.
When you do svn --version though a build step you will see the same version because the svn plugin has it's own svn library called svnkit (version 1.7.4) which allows you to do things like svn update without having to actually install svn.
Re: hudson and .svn [message #903737 is a reply to message #903736] Sat, 25 August 2012 05:44 Go to previous messageGo to next message
My svn plugin version 2.3.3 too
Re: hudson and .svn [message #903740 is a reply to message #903737] Sat, 25 August 2012 06:44 Go to previous messageGo to next message
I have done downgrade hudson to 2.2.0 and it solved my problem! I suppose, that maybe it is bug in version 2.2.1.
Re: hudson and .svn [message #903741 is a reply to message #903740] Sat, 25 August 2012 06:59 Go to previous message
Yes you are right! After upgrading the pom.xml file to 2.2.1 I am finding that a couple critical test units are failing. The pom is currently set for 2.2.0 which seems to have no issues. I will fix these and run a quick test along with a release for it ASAP.
Previous Topic:GIT No changes on repo -> Nothing to do FAILURE
Next Topic:LDAP roles as parameters to scripts
Current Time: Wed Jul 23 07:34:56 EDT 2025
Powered by FUDForum. Page generated in 0.05652 seconds
