Home » Archived » BIRT » report parameter as dataset filter works in dev, not on production
report parameter as dataset filter works in dev, not on production [message #903584] Fri, 24 August 2012 08:24 Go to next message
so I successfully created my nested table, (Thanks Jason), and migrated it to the production system (Birt 3.2.21)
my leaf most dataset uses a defined filter (its second filter) which uses the report parameter.
in the designer testing it work perfectly..
in the production system this parameter appears to be ignored.
the Birt version shipped with IBM Ration Team Concert is unknown to me,
but the product shipped last October, and the major version was released June 2011,
over year ago..
(so this could be a bug or lack of feature in the runtime)
is there another way, short of passing the parm thru the nested tables as a calculated field? (this wouldn't be hard, just time consuming)
Sam
Re: report parameter as dataset filter works in dev, not on production [message #903623 is a reply to message #903584] Fri, 24 August 2012 11:06 Go to previous messageGo to next message
Sam
Can you put that file io im I sent you in the filter to see what the
parameter value is when the filter is calculated?
Jason
> in the designer testing it work perfectly.. in the production system
> this parameter appears to be ignored. the Birt version shipped with IBM
> June 2011,
> over year ago..
> Thanks
> Sam
Re: report parameter as dataset filter works in dev, not on production [message #903638 is a reply to message #903623] Fri, 24 August 2012 11:42 Go to previous messageGo to next message
that out.print will run on the server and store on the server disk, which I don't have access to
Re: report parameter as dataset filter works in dev, not on production [message #903644 is a reply to message #903638] Fri, 24 August 2012 12:20 Go to previous messageGo to next message
Can you add a data item to the table and set its value to
params["yourparametername"]
Jason
Re: report parameter as dataset filter works in dev, not on production [message #903649 is a reply to message #903644] Fri, 24 August 2012 13:07 Go to previous messageGo to next message
on the production server the parameter is in 'quotes'.
the input is UDM, the displayed calculated column is 'UDM'
(I didn't add the quotes)
Re: report parameter as dataset filter works in dev, not on production [message #903653 is a reply to message #903649] Fri, 24 August 2012 13:30 Go to previous messageGo to next message
and the function we put in to control visibility of the headers also isn't working.
on the production machine
so I deployed the report design as a template
then created a report from the template
then ran the report (it prompted for project name)
it reported the right stuff except
1. the filter didn't exclude records
2. the functions on the header rows didn't fire
Re: report parameter as dataset filter works in dev, not on production [message #903673 is a reply to message #903653] Fri, 24 August 2012 16:15 Go to previous messageGo to next message
Sam
Do you have any details on the production server?
Is is using the BIRT viewer? What is the url to run the report?
Jason
> isn't working.
Re: report parameter as dataset filter works in dev, not on production [message #903675 is a reply to message #903673] Fri, 24 August 2012 16:22 Go to previous messageGo to next message
quotes is a known difference
jazz.net/wiki/bin/view/Main/ReportsViewingDifferences
[Updated on: Fri, 24 August 2012 16:23] by Moderator
Re: report parameter as dataset filter works in dev, not on production [message #903682 is a reply to message #903675] Fri, 24 August 2012 17:11 Go to previous message
this is working now
Previous Topic:how to edit the value of a result table field
Next Topic:BIRT 2.7 WebSphere 7
Current Time: Thu Jul 17 19:17:09 EDT 2025
Powered by FUDForum. Page generated in 0.06799 seconds
