Home » Modeling » EMF » [EMF Compare] Steps to do Graphical Comparison with Eclipse (Solved)(How can I do a graphical comparison of 2 *.ecorediag files?)
[EMF Compare] Steps to do Graphical Comparison with Eclipse (Solved) [message #891710] Mon, 25 June 2012 10:56 Go to next message
How do I get graphical comparisons of 2 *.ecorediag models with EMF compare
I am using Eclipse 3.7 and EMF and EMF compare from the Eclipse update site: HTTP : //download. eclipse. org/releases/indigo.
I have 2 versions of diff.ecorediag. When I run compare versions with Eclipse I only get an XML comparison, or an error that is similar to the other post number 362541.
What do I need to install, or do to get a graphical comparison that is explained at wiki. eclipse. org/EMF_Compare_1.0.0_New_And_Noteworthy#Draft_Graphical_Modelers_Integration?
Thank you for your assistance.
[Updated on: Fri, 24 August 2012 14:59] by Moderator
Re: [EMF Compare] Steps to do Graphical Comparison with Eclipse (Solved) [message #903664 is a reply to message #891710] Fri, 24 August 2012 15:00 Go to previous messageGo to next message
You cannot do graphical comparison with Version 2.0 yet. It only works with Version 1.3
Re: [EMF Compare] Steps to do Graphical Comparison with Eclipse (Solved) [message #903898 is a reply to message #903664] Mon, 27 August 2012 04:04 Go to previous message
To be more precise, graphical comparison is expected to be back in the feature list of EMF Compare for version 2.1, initially scheduled for october.
Laurent Goubet
Obeo
Previous Topic:EAnnotation references between ecore models
Next Topic:Doxygen documentation
Current Time: Sun Jul 27 11:20:27 EDT 2025
Powered by FUDForum. Page generated in 0.19040 seconds
