Home » Eclipse Projects » Remote Application Platform (RAP) » Selection is cleared in IE9
Selection is cleared in IE9 [message #903479] Thu, 23 August 2012 15:14 Go to next message
RAP 1.5
We are experiencing a problem only in IE7 and IE9 during right click in a Text widget. If the user selects a text in the Text widget and then press right click, the selection is cleared and our pop-up menu is displayed. The selection should not be cleared when you right click. The problem occurs only when we set a context menu in the Text widget. If the Text widget will have no context menu then the browser default context menu (copy, paste,...) is displayed and the selection is not cleared.
To easily reproduce this problem, use the mail demo example, and add the lines below to the end of the createPartControl method in the view class.
final AboutAction action = new AboutAction(Activator.getDefault().getWorkbench().getActiveWorkbenchWindow());
MenuManager menuManager = new MenuManager("menu"); //$NON-NLS-1$
menuManager.add(action);
menuManager.update();
Menu menu = menuManager.createContextMenu(parent);
text.setMenu(menu);
[Updated on: Thu, 23 August 2012 16:28] by Moderator
Re: Selection is cleared in IE9 [message #903540 is a reply to message #903479] Fri, 24 August 2012 04:23 Go to previous messageGo to next message
Hi!
I can reproduce it with current master also. Could you please open an
entry on bugzilla?[1] Thanks.
[1]
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=RAP&rep_platform=All&op_sys=all
Greetings,
Tim
Tim Buschtöns
Twitter: @EclipseRAP
Re: Selection is cleared in IE9 [message #903602 is a reply to message #903540] Fri, 24 August 2012 09:37 Go to previous message
I opened bug number 387987. Thank you.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=387987
Previous Topic:Display a string in Table when there are no items
Next Topic:RAP based UI to the marketplace client
Current Time: Sat Jul 19 00:17:02 EDT 2025
Powered by FUDForum. Page generated in 0.04444 seconds
