Home » Modeling » EMF » Which EMF Compare for EMF 2.4
Which EMF Compare for EMF 2.4 [message #903570] Fri, 24 August 2012 07:32 Go to next message
Please would some-one be able to assist.
I want to use EMF Compare against EMF 2.4 and looking at the compatibility chart at:
http://wiki.eclipse.org/EMF_Compare
It was confusing which version to use.
Things that are supported seem to be in Green with the text OK.
Things that are not supported are in Red with the text KO
However with the 1.3 version of EMF Compare it is in green but with the text KO.
So a little confusion?
The bottom line is - which is the best version of EMF Compare to use against EMF 2.4?
Rob
Re: Which EMF Compare for EMF 2.4 [message #903896 is a reply to message #903570] Mon, 27 August 2012 04:00 Go to previous messageGo to next message
This was a typo in the wiki page which has now been solved. Support for Eclipse 3.4 / EMF 2.4 has been discontinued with EMF Compare 1.3. The last version of EMF Compare that supported Eclipse 3.4 is version 1.2 (tou can find the latest version on the 1.2 update site.
Laurent Goubet
Obeo
Re: Which EMF Compare for EMF 2.4 [message #904305 is a reply to message #903896] Tue, 28 August 2012 03:56 Go to previous message
Thank you for the clarification and correction - 1.2 it is!
Thanks, Rob
Previous Topic:[EMF Compare] Hide Nodes
Next Topic:Extending DeleteAction/Command not undoable
Current Time: Sun Jul 27 14:12:19 EDT 2025
Powered by FUDForum. Page generated in 0.04541 seconds
