Home » Modeling » EMF » Tabbed Properties
Tabbed Properties [message #903423] Thu, 23 August 2012 11:01 Go to next message
Hi everyone.
I'm kind newbie in EMF and associated.
I wanted to have tabbed properties withou tabs, i.e. A want properties in a composite with form elements, but as I only have "one tab", I don't want any tab at all. Is that possible?
Thanks in advance
Re: Tabbed Properties [message #903448 is a reply to message #903423] Thu, 23 August 2012 12:39 Go to previous messageGo to next message
Rui,
I'd suggest looking at EEF.
On 23/08/2012 5:01 PM, Rui Domingues wrote:
> Hi everyone.
> Thanks in advance
Re: Tabbed Properties [message #903533 is a reply to message #903448] Fri, 24 August 2012 03:47 Go to previous messageGo to next message
Hi Rui,
maybe the EMF Client Platform is also an option:
http://eclipse.org/emfclient/
Maximilian
Am 23.08.2012 18:39, schrieb Ed Merks:
> Rui,
>> Hi everyone.
>> Thanks in advance
Maximilian Kögel
Get Professional Eclipse Support: http://eclipsesource.com/munich
Re: Tabbed Properties [message #903535 is a reply to message #903423] Fri, 24 August 2012 03:58 Go to previous messageGo to next message
Hi Rui,
Just to be completely clear, the TabbedProperties plugins cannot manage
this case. You have to include your composite in a Section which itself
have to be include in a Tab to display your widgets.
So if you want a "Eclipse Forms Composite", EEF can generate it for you,
but you will have to integrate this composite by yourself in the
properties view (which can be relatively complicated) or in another view.
Goulwen Le Fur - goulwen.lefur@xxxxxxxx
Le 23/08/2012 17:01, Rui Domingues a écrit :
> Hi everyone.
> Thanks in advance
Re: Tabbed Properties [message #903536 is a reply to message #903533] Fri, 24 August 2012 04:04 Go to previous messageGo to next message
Hi. Thanks to both of you.
I'll try EMF Platform.
Actually, I was definining my view to show properties, but when I bind it with Jfaces, it doesnt work properly.
When model elements are associated to a resource it kinda works as i expected, but when it is associated to a file resource it doesnt work fine.
Is this suposed? What I was trying should work?
Thanks again
Re: Tabbed Properties [message #903538 is a reply to message #903535] Fri, 24 August 2012 04:08 Go to previous message
Hum. Ok.
So I defined my own view which captures the current selection and shows the properties.
But the binding with Jfaces doesn't work properly, specially when model is associated to a resource file.
thanks
Previous Topic:[CDO] What does CDO_VERSION -2 signify?
Next Topic:How to get nationalized feature name
Current Time: Thu Jul 24 22:59:09 EDT 2025
Powered by FUDForum. Page generated in 0.03571 seconds
