Home » Eclipse Projects » Eclipse Platform » loading descriptor bug(problem creating or importing project in new workspace)
loading descriptor bug [message #903397] Thu, 23 August 2012 09:33 Go to next message
I'm getting a variation of a problem reported in Bugzilla earlier. "Loading descriptor" won't complete. When I click on the loading descriptor icon in the project explorer it causes an exception, as logged below. This happens when importing or creating a dynamic web project in a new workspace.
I have tried various things like setting validators off, and disabling XML header conformance, to no avail. Something like this was discussed earlier, in
https://bugs.eclipse.org/bugs/show_bug.cgi?id=383293
but attributed to Glassfish, which is not present here. There is other chatter around the web. I had a similar problem in Indigo, but was always able to cancel the tardy loading descriptor process, can't here. Any comments? Should I file a bug report? Thanks
!SESSION 2012-08-23 08:57:36.623 -----------------------------------------------
eclipse.buildId=I20120608-1400
java.version=1.7.0_05
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments:  -product org.eclipse.epp.package.jee.product
Command-line arguments:  -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.jee.product
!ENTRY org.eclipse.jface 4 2 2012-08-23 09:03:04.210
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.jface".
!STACK 0
	at org.eclipse.jst.j2ee.commonarchivecore.internal.util.ArchiveUtil.getModuleFile(ArchiveUtil.java:342)
	at org.eclipse.jst.jee.ui.internal.navigator.OpenJEEResourceAction.openEObject(OpenJEEResourceAction.java:388)
	at org.eclipse.jst.jee.ui.internal.navigator.OpenJEEResourceAction.run(OpenJEEResourceAction.java:339)
	at org.eclipse.ui.actions.RetargetAction.run(RetargetAction.java:221)
	at org.eclipse.ui.navigator.CommonNavigatorManager$3.open(CommonNavigatorManager.java:185)
	at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
	at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:866)
	at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
	at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
	at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:864)
	at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1152)
	at org.eclipse.ui.navigator.CommonViewer.handleOpen(CommonViewer.java:462)
	at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1256)
	at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:275)
	at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:269)
	at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:309)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1022)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:585)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Re: loading descriptor bug [message #903422 is a reply to message #903397] Thu, 23 August 2012 10:52 Go to previous message
I probably should have entered this in WTP Jave EE Tools. I did create a bug report there.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=387899
Previous Topic:Variable reference in classpath
Next Topic:FastView in Eclipse Juno
Current Time: Sun Jul 27 02:18:52 EDT 2025
Powered by FUDForum. Page generated in 0.39982 seconds
