Home » Modeling » Graphiti » Create dynamically anchors on a shape
Create dynamically anchors on a shape [message #903145] Wed, 22 August 2012 04:16 Go to next message
hi, i think there are some similar problems but i couldn't get smart of them.
This is the problem:
I have a Rectangle on my Diagram
	public PictogramElement add(IAddContext context) {
		Shape ladder = createLadderGraphic(context);
		getDiagram().eResource().getContents()
				.add((EObject) context.getNewObject());
		link(ladder, context.getNewObject());
		return ladder;
	private Shape createLadderGraphic(IAddContext context) {
		Diagram targetDiagram = (Diagram) context.getTargetContainer();
		IGaService gaService = Graphiti.getGaService();
		IPeCreateService peCreateService = Graphiti.getPeCreateService();
		Ladder bo = (Ladder) context.getNewObject();
		// 1 containershape
		ContainerShape containerShape = peCreateService.createContainerShape(
				targetDiagram, true);
		Rectangle rectangle = gaService.createRectangle(containerShape);
		rectangle.setBackground(manageColor(StyleUtil.COLOR_BLACK));
		rectangle.setFilled(true);
		gaService.setLocationAndSize(rectangle, context.getX(), context.getY(),
				context.getWidth(), context.getHeight());
		return containerShape;
Works Smile
Now this what i am trying....
Creating a Connection from the location i clicked in the shape to the target.
I hooked into attach
	public void attachedToSource(final ICreateConnectionContext context) {
		final Object bo = getBusinessObjectForPictogramElement(context
				.getSourcePictogramElement());
		// create fix anchor for connection on ladder
		if (bo instanceof StartLadder) {
			TransactionalEditingDomain editingDomain = getDiagramEditor()
					.getEditingDomain();
			CommandStack commandStack = editingDomain.getCommandStack();
			commandStack.execute(new RecordingCommand(editingDomain) {
				protected void doExecute() {
					ContainerShape container = (ContainerShape) context
							.getSourcePictogramElement();
					ILocation location = context.getSourceLocation();
					int x = location.getX();
					int y = location.getY();
					// Point p = gaService.createPoint(x, y);
					ChopboxAnchor anchor = peCreateService
							.createChopboxAnchor(container);
					// gaService.setLocation(anchor, x, y);
					// anchor.setUseAnchorLocationAsConnectionEndpoint(true);
					Rectangle rect = gaService.createRectangle(anchor);
					gaService.setLocation(rect, x, y);
					anchor.setGraphicsAlgorithm(rect);
					anchor.setReferencedGraphicsAlgorithm(rect);
					IEC_Anchor obj = FbsFactory.eINSTANCE.createIEC_Anchor();
					obj.setIn(false);
					obj.setSource((EObject) bo);
					getDiagram().eResource().getContents().add(obj);
					// link(shape, obj);
					link(anchor, bo);
					// use anchor
					((CreateConnectionContext) context).setSourceAnchor(anchor);
looking the attached jpg.
but i dont want chopbox anchor because it starts from the middle of the shape.
any hints?
BR
Thomas
Re: Create dynamically anchors on a shape [message #903153 is a reply to message #903145] Wed, 22 August 2012 05:03 Go to previous messageGo to next message
When i do this:
					int x = 0;// location.getX();
					int y = location.getY()-20;
					FixPointAnchor anchor = peCreateService
							.createFixPointAnchor(container);
					anchor.setLocation(gaService.createPoint(x, y));
					gaService.setLocationAndSize(rect, 0, 0, 1, 1);
					// anchor.setGraphicsAlgorithm(rect);
					// anchor.setReferencedGraphicsAlgorithm(rect);
					obj.setIn(false);
					link(anchor, bo);
					// use anchor
its working. the next step is when i create the connection i have to look up for the right anchor.
looking something like this
	public Connection create(ICreateConnectionContext context) {
		// create the domain object connection here
		SignalFlow flow = FbsFactory.eINSTANCE.createSignalFlow();
		// check if horizontal
		int sx = context.getSourceLocation().getX();
		int sy = context.getSourceLocation().getY();
		int tx = context.getTargetLocation().getX();
		int ty = context.getTargetLocation().getY();
		if (Math.abs(tx - sx) >= Math.abs(ty - sy)) {
			flow.setHorizontal(true);
		} else {
			flow.setHorizontal(false);
			EList<Anchor> anchors = ((ContainerShape) context
					.getSourcePictogramElement()).getAnchors();
			Anchor a2use = null;
			for (Anchor anchor : anchors) {
				Object anchorBO = getBusinessObjectForPictogramElement(anchor);
				a2use = anchor;
				break;
			((CreateConnectionContext) context).setSourceAnchor(a2use);
It is both done in a #AbstractConnectionPattern
But there is a bug or missing implementation. Starting to create the connection brings result1.jpg
The reason is that i have no anchor defined on my containershape and i allow to canStartConnecting() (the laddergraphix), a "default chopbox" anchor is used.
I am able to handle this?
BR
Thomas
  • Attachment: result1.jpg
    (Size: 109.78KB, Downloaded 378 times)
  • Attachment: result2.jpg
    (Size: 106.88KB, Downloaded 1322 times)
Re: Create dynamically anchors on a shape [message #903411 is a reply to message #903153] Thu, 23 August 2012 10:21 Go to previous messageGo to next message
Hi, i found an example where my needs are implemented (but in GMF, i think).... GEB automation IDE. When you are opening a new functionblcokdiagram (type: ladder) and create a connection on the start ladder, it follows the mouse move....
How can i hook-into to the GFConnectionCreationTool.class in package org.eclipse.gef.tools; ?? i think there i have to look for my needs.
BR
Thomas
Re: Create dynamically anchors on a shape [message #903706 is a reply to message #903153] Thu, 23 August 2012 08:00 Go to previous messageGo to next message
The anchor you allow for starting the connection is the one used while
drawing the connection. If you do not want this behavior you will need to
retrict starting the connection to your anchor only.
I hope that answers your question
Michael
Re: Create dynamically anchors on a shape [message #903710 is a reply to message #903411] Fri, 24 August 2012 03:10 Go to previous messageGo to next message
Thomas,
Graphiti hides GEF in most areas from clients and it is not intended that
clients modify classes like GFConnectionCreationTool. If you want to replace
it your should look into DeafultPaletteBehavior where GFPaletteRoot is
created that defines again which tools will be added to the palette (beyond
others also GFConnectionCreationTool). But don't take this as the
recommendation to do this...
Did you read my other reply?
Michael
Re: Create dynamically anchors on a shape [message #904349 is a reply to message #903145] Tue, 28 August 2012 05:45 Go to previous message
Thanks for the replay,
i think i am going to solve this problem with the
ConnectionFeatures, as described above, keeping it as simple as possible.
BR,
Thomas
Previous Topic:One CreateFeature for many palette entries
Next Topic:MoveContext
Current Time: Fri Jul 25 21:42:01 EDT 2025
Powered by FUDForum. Page generated in 0.06229 seconds
