Debugging not working while running works [message #903393] |
Thu, 23 August 2012 09:22  |
I've been having problems debugging my code in Eclipse. For some reason debugging does not work. Building an executable works fine. I can run it in terminal but when I want to debug, it crashes. Here is my simple code.
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
int main(void)
static const char filename[] = "test.txt";
FILE *file = fopen ( filename, "r" );
if ( file != NULL )
char line [ 128 ];
while ( fgets ( line, sizeof line, file ) != NULL )
fputs ( line, stdout );
fclose ( file );
else
perror ( filename );
return 0;
The debugger runs until fopen and than it crashes and says:
Quote:Can't find a source file at "../sysdeps/wordsize-64/../../libio/iofopen.c"
Locate the file or edit the source lookup path to include its location.
This while normally running the code (ctrl+F11) does give the desired result. Also running the executable in terminal gives the desired result. Anyone have ideas?
FUDForum. Page generated in 0.05339 seconds
