Home » Archived » BIRT » Show/Hide Chart with Radio Button(Show/Hide Chart with Radio Button)
Show/Hide Chart with Radio Button [message #903281] Wed, 22 August 2012 15:56 Go to next message
Hi I have copied the example from DevShare and added parameter, which is not part of logic. Here I have the following senario:
- Is it possible after the radio button selection , the report will execute and pop up parameter?
If possibl how?
- Is it possible to impliment the same on two multiple grids?
- By default show contents of one grid and on selection of radio button pop up for the parameter?
I am using BIRT 2.6.1
AR
Re: Show/Hide Chart with Radio Button [message #903426 is a reply to message #903281] Thu, 23 August 2012 11:01 Go to previous messageGo to next message
If you want to show parameters why not just hyperlink to a new report.
Jason
> If possibl how?
> Thanks
> AR
Re: Show/Hide Chart with Radio Button [message #911566 is a reply to message #903426] Tue, 11 September 2012 17:52 Go to previous messageGo to next message
I am using the same option Jason !
How ever I am trying to learn , if it is possible.
Thank you Smile
AR
Re: Show/Hide Chart with Radio Button [message #912451 is a reply to message #911566] Thu, 13 September 2012 11:54 Go to previous messageGo to next message
What I was thinking is that you create one report with check boxes in text elements. After select you can forward to a new report with the settings. Does this sound like what you need?
Jason
Re: Show/Hide Chart with Radio Button [message #939880 is a reply to message #912451] Thu, 11 October 2012 01:32 Go to previous messageGo to next message
Not exactly Jason.
As suggested prev answer, I am using hyperlink as a solution. But here I a have a
issue that, I need to modify the link manually from environment to environment. Is there any way that I can use any configuration file where I can manipulate the link depending on the environment.
note: I need to deploy the report in SOA environment.
AR
Re: Show/Hide Chart with Radio Button [message #941647 is a reply to message #939880] Fri, 12 October 2012 14:51 Go to previous message
It is a property so you should be able to do this. If you had a data item that you wanted to customize a drill through on you could put an oncreate script on it like"
var rpt = this.getRowData().getColumnValue("STATUS");
var myaction =this.createAction();
importPackage(Packages.java.util);
var hm = new HashMap();
hm.put("order",row["ORDERNUMBER"]);
this.action = myaction;
var dt =this.action.createDrillThrough();
dt.setReportName(rpt+".rptdesign");
dt.setTargetWindow("_blank");
dt.setTargetFileType("report-design");
dt.setParameterBindings( hm );
myaction.setDrillThrough( dt );
Jason
Previous Topic:Dynamic URL
Next Topic:MS Excel data connection to BIRT report not working => SOLVED!!
Current Time: Sat Jul 26 21:02:02 EDT 2025
Powered by FUDForum. Page generated in 0.08036 seconds
