convert datetime to date report parameter [message #901810] |
Tue, 14 August 2012 12:07  |
Where and how can I convert a datetime report parameter to date format for use in my sql query? The LMS I'm using now requires that report date parameters be in datetime format. I want to convert the dateteime report format to date and use it in my sql query where clause.
When the LMS previously allowed date report parameters I was able to reference the date report in my sql query by reference the date report parameter. Now if I convert the datetime report parameter to date, how do I reference it in my sql dataset query, and where in the report processing stage do I convert the datetime report parameter, before the dataset or table that holds the data from query is initialized.
Re: convert datetime to date report parameter [message #903585 is a reply to message #903280] |
Fri, 24 August 2012 08:25  |
Good question... let me see if I can be a li'll more specific.
the report parameter is rpStartDte.
the new version on the lms require that date parameters be dateTime (birt) format as opposed to the old way date (birt) format.
1. Example one works (report parametere is Date.
The old way using Date format report parameter works in my property binding, ex.
" where r2.chkStartDate = to_date('" + params["rpStartDte"] + "','mm/dd/yyyy') " +
2. This doesn't work, mainly because I don't know how to format map dateTime, ex.
report parametere is DateTime:
" where r2.chkStartDate = to_date('" + params["rpStartDte"] + "','mm/dd/yyyy hh:mi:ss') " +
how can I get #2 to work? I'm getting datetime format errors.
I'm using BIRT 2.6.1 and Oracle 11g
Some of errors I'm getting.
java.sql.SQLException: ora-01841: (full) year must be between -4713 and +9999, and not be 0.
or if i change the datetime map, i'll get "invalid month".
Also, now that the report parameter must be datetime, the customers are still putting the date in as 6/19/2012, so I'm assuming the default if you don't put the time is something like "6/19/2012 12:00:00" or "6/19/2012 00:00:00".
Crazy huh? But like I said the code worked up until he had to dateime report parameter format instead of date. Help!!!!
I've attached some screen shots.
FUDForum. Page generated in 0.20242 seconds
