Home » Modeling » Papyrus » Sequence diagram basics(Need additional manuals, tutorials, or examples)
Sequence diagram basics [message #894647] Mon, 09 July 2012 20:18 Go to next message
I have been playing with Papyrus for about a day. I have watched all the instruction videos I can find and have read two PDF files (TutorialOnPapyrusUSE_d20101001 and PapyrusTutorial_OnSequenceDiagrams_v0.1_d2010100). I have successfully created class diagrams. I cannot understand how to create sequence diagrams.
My stumbling blocks are:
1. I do not understand how classes/types are supposed to be associated with Lifelines. I learned from another post that to select the class/type of a Lifeline, I have to create a property/parameter/... and associate *that* with a class. I do not understand why. I do not understand how or where this should be done.
2. I hacked my was past (1) by creating property elements as children of a dummy node. I then changed the type of the property to a particular class. Only then could I assign a class to a Lifeline. However, I could not create an async message from one Lifeline to another. I added an operation on the class called simulate(). I expected that dragging the async connector from one Lifeline to another would allow me to invoke the call the operation simulate(). However, that is not the case. I see only the circle-with-a-line-through-it icon.
I need additional examples, samples, manuals, documentation, or tutorials. What am I missing?
Re: Sequence diagram basics [message #903269 is a reply to message #894647] Wed, 22 August 2012 15:00 Go to previous messageGo to next message
For example, create class diagram:
Class1 --- Class2
--- is the association class1_class2 with Member Ends: class1 and class2. Set the owner of both member ends the association.
Now You can create sequence diagram:
class1:Class1 -msg-> class2:Class2
First lifeline is associated with first member end of association, second -- with the second. Then you create the message, choice "No member". After creation of the message assign the operation in Signature field.
Re: Sequence diagram basics [message #947957 is a reply to message #894647] Wed, 17 October 2012 12:01 Go to previous message
Dear Aaron Hoffer
i find this link that i think it is useful
(www.youtube.com/watch?v=JMTQlhglZLM)
regards
Previous Topic:SysML: flow, proxy and full ports
Next Topic:request reference in MARTE profile of UML using Papyrus
Current Time: Sun Jul 20 21:47:30 EDT 2025
Powered by FUDForum. Page generated in 0.04927 seconds
