Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » orm:delimited-identifiers
orm:delimited-identifiers [message #903170] Wed, 22 August 2012 07:30 Go to next message
Hi, I upgraded to a new version of texo and was regenerating our orm.xml. I was able to change some settings in the annotations-model in order to get more or less the same orm.xml I had before. One thing is missing, though: The new texo generates
  <orm:persistence-unit-metadata>
    <orm:persistence-unit-defaults>
      <orm:delimited-identifiers/>
    </orm:persistence-unit-defaults>
  </orm:persistence-unit-metadata>
in the beginning. My application does no longer work with that option. How can I tell texo not to generate the delimited-identifiers option?
Thanks & regards,
Peter
Re: orm:delimited-identifiers [message #903292 is a reply to message #903170] Wed, 22 August 2012 17:51 Go to previous messageGo to next message
Hi Peter,
As a default this is always set. I will change it to work with the reserved sql word option.
Can you enter a bugzilla for this?
gr. Martin
> generates
> Thanks & regards,
> Peter
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: orm:delimited-identifiers [message #903547 is a reply to message #903292] Fri, 24 August 2012 04:53 Go to previous message
Here it is: https://bugs.eclipse.org/bugs/show_bug.cgi?id=387954
Greetings,
Peter
Previous Topic:[texo] how to set references in json
Next Topic:[EMF Compare] opening editor programmatically results in unexpected/wrong view
Current Time: Wed Jul 23 12:39:11 EDT 2025
Powered by FUDForum. Page generated in 0.24908 seconds
