Home » Newcomers » Newcomers » Eclipse WAR builds contains .java files(When building .java files gets included even though export sources are unchecked)
Eclipse WAR builds contains .java files [message #903161] Wed, 22 August 2012 06:33 Go to next message
When i export my www project to a WAR file it also puts all my source files in the WAR file
The export source checkbox is unchecked.
Does anyone have any ideas as to why this happens?
Thanks in advance!
Re: Eclipse WAR builds contains .java files [message #903306 is a reply to message #903161] Thu, 23 August 2012 02:15 Go to previous messageGo to next message
What's the layout of your project? Is there anything unusual about it? Where were the .java files in relation to the .class files?
Re: Eclipse WAR builds contains .java files [message #903315 is a reply to message #903306] Thu, 23 August 2012 03:04 Go to previous messageGo to next message
as far as i know the project is pretty standard
i have taken it over from a colleague
when he builds it with an older version of eclipse it doesnt happen
i have the newest EE (juno) installed
the java files are outputted to the same folder structures as the class files
so they are in the same location
Re: Eclipse WAR builds contains .java files [message #903760 is a reply to message #903315] Sat, 25 August 2012 11:11 Go to previous messageGo to next message
As far as I know, I don't konw what it happened.
But maybe you can use "Exclude" item in the "source" tab in "java build path"
Re: Eclipse WAR builds contains .java files [message #903770 is a reply to message #903760] Sat, 25 August 2012 14:20 Go to previous message
seems to be a bug in the juno release
Previous Topic:debugging struts using eclipse
Next Topic:Run panel is blank
Current Time: Sun Jul 20 22:40:57 EDT 2025
Powered by FUDForum. Page generated in 1.12171 seconds
