Home » Modeling » EMF » How to read transient EAttibute?
How to read transient EAttibute? [message #902981] Tue, 21 August 2012 09:57 Go to next message
Hi All,
I have transient EAttribute "isLoaded" in my targetMetamodel.
protected IModel inModel;
protected IModel outModel;
public void loadModels(String inputModelPath) throws ATLCoreException {
EMFModelFactory factory = new EMFModelFactory();
IInjector injector = new EMFInjector();
IReferenceModel sourceMetamodel = factory.newReferenceModel();
injector.inject(sourceMetamodel, this.getSourceMetamodelPath());
IReferenceModel targetMetamodel = factory.newReferenceModel();
injector.inject(targetMetamodel, getPackage_eNS_URI());
this.inModel = factory.newModel(sourceMetamodel);
injector.inject(inModel, inputModelPath);
this.outModel = factory.newModel(targetMetamodel);
public EObject getModelObjects() throws ATLCoreException, IOException {
getPackage_eINSTANCE().getClass();
final PipedOutputStream outputStream = new PipedOutputStream();
PipedInputStream inputStream = new PipedInputStream(outputStream);
//read from outputStream
new Thread(new Runnable() {
public void run() {
try {
(new EMFExtractor()).extract(outModel, outputStream, null);
} catch (ATLCoreException e) {
e.printStackTrace();
try {
outputStream.close();
} catch (IOException e) {
}).start();
//load EObject from inputStream
XMIResourceImpl resource = new XMIResourceImpl();
resource.load(inputStream, new HashMap<Object,Object>());
EObject obj = resource.getContents().get(0);
// return EObject
return obj;
When I debug this program, the proper values can be found in outModel at getModelObjects() method.
Problem: I need to read outModel and return it as an object. For that I use PipedStream and XMIResourceImpl. isLoaded is transient and it does not support serialization therefore i always get false, which is the default.
Is there any way to read outModel to return as an object without serialization, since i need to capture transient variables?
Thanks in advance!
Kosala
Re: How to read transient EAttibute? [message #902989 is a reply to message #902981] Tue, 21 August 2012 10:28 Go to previous messageGo to next message
Kosala,
It's expect that all serializers respect isTransient by not serializing
that data. If you want to override that, you'd have to specialize
XMLSaveImpl/XMISaveImpl. In particular, the Lookup class has a
featureKind method guarded like this:
protected int featureKind(EStructuralFeature f)
if (f.isTransient())
return TRANSIENT;
On 21/08/2012 3:57 PM, Kosala Yapa wrote:
> Hi All,
> public void run() {
> try {
> try {
> }).start();
> // return EObject
> return obj;
> the default.
> Thanks in advance!
> Kosala
Re: How to read transient EAttibute? [message #903131 is a reply to message #902989] Wed, 22 August 2012 03:40 Go to previous message
Thanks a mil Ed.
I solved the issue, without serialization.
I wanted to capture an object from outModel which is IModel.
here is my code.
EMFModel m= (EMFModel)outModel;
Resource resource = m.getResource();
EObject obj=resource.getContents().get(0);
Kosala
Previous Topic:Xcore for Indigo
Next Topic:[CDO/Hibernate] Default values are not recognized
Current Time: Wed Jul 23 12:39:49 EDT 2025
Powered by FUDForum. Page generated in 0.06377 seconds
