Home » Modeling » EMF » [CDO] "Different object was registered for OID XX" in Native mode
[CDO] "Different object was registered for OID XX" in Native mode [message #902825] |
Mon, 20 August 2012 11:57  |
Hi everyone,
I'm facing the "different object was registered for OID XX" issue with CDO, although I think my use case is legit.
My Repository contains :
- a CDOResource A containing a root r1
- a CDOResource B containing a root r2 referencing r1
Both r1 and r2 are in CDONative mode (no Legacy here).
When I load r2 and get its lists of referenced elements,
this calls AbstractCDOView.getObject(r1's CDOID)
which creates a new Java instance for r1 as it is not in the 'objects' map of my transaction yet.
When creating r1 (inside createObject(r1's CDOID)), we call the cleanObject() method before putting r1 in the 'objects' map.
This clean Object bethods, by setting the state of R1 to CLEAN, notifies the CleanObjectHandler, which asks for r1's CDOResource (by a call to isContained()):
CDOStoreImpl.getResource(InternalEObject) line: 163
R1Impl(CDOObjectImpl).eDirectResource() line: 456
R1Impl(BasicEObjectImpl).eInternalResource() line: 931
R1Impl(CDOObjectImpl).eInternalResource() line: 467
R1Impl(BasicEObjectImpl).eResource() line: 926
R1Impl(CDOObjectImpl).cdoResource() line: 127
CDOModificationTrackingAdapter(CDOLazyContentAdapter).isContained(CDOObject) line: 212
CDOLazyContentAdapter.access$2(CDOLazyContentAdapter, CDOObject) line: 197
CDOLazyContentAdapter$CleanObjectHandler.objectStateChanged(CDOView, CDOObject, CDOState, CDOState) line: 227
CDOTransactionImpl(AbstractCDOView).handleObjectStateChanged(InternalCDOObject, CDOState, CDOState) line: 967
R1Impl(CDOObjectImpl).cdoInternalSetState(CDOState) line: 228
CDOTransactionImpl(AbstractCDOView).cleanObject(InternalCDOObject, InternalCDORevision) line: 746
CDOTransactionImpl(AbstractCDOView).createObject(CDOID) line: 691
CDOTransactionImpl(AbstractCDOView).getObject(CDOID, boolean) line: 605
The problem is that, when loading r1's CDOResource, we try to install ContentAdapters on this CDOResource and its children, including r1. At this moment, when trying to get r1 from the 'objects' map, as we have not put it on the map yet it's created twice:
CDOTransactionImpl(AbstractCDOView).newInstance(EClass) line: 553
CDOTransactionImpl(AbstractCDOView).createObject(CDOID) line: 687
CDOTransactionImpl.getObject(CDOID, boolean) line: 885
CDOTransactionImpl(AbstractCDOView).convertIDToObject(Object) line: 860
CDOStoreImpl.convertIDToObject(InternalCDOView, EObject, EStructuralFeature, int, Object) line: 668
CDOStoreImpl.convertToEMF(EObject, InternalCDORevision, EStructuralFeature, int, Object) line: 636
CDOStoreImpl.get(InternalEObject, EStructuralFeature, int) line: 187 CDOResourceImpl$ContentsCDOList(EStoreEObjectImpl$BasicEStoreEList<E>).delegateGet(int) line: 247
CDOResourceImpl$ContentsCDOList(DelegatingEList<E>).primitiveGet(int) line: 267
AbstractEList$NonResolvingEListIterator<E1>.doNext() line: 1063
AbstractEList$NonResolvingEListIterator<E1>(AbstractEList$EIterator<E1>).next() line: 696
EContentsEList$FeatureIteratorImpl<E>.hasNext() line: 443
TransactionChangeRecorder.setTarget(Notifier) line: 155
CDOObjectImpl$1(BasicNotifierImpl$EAdapterList<E>).didAdd(int, E) line: 127
CDOObjectImpl$1.didAdd(int, Adapter) line: 419
CDOObjectImpl$1.didAdd(int, Object) line: 1
CDOObjectImpl$1(BasicEList<E>).addUnique(E) line: 425
CDOObjectImpl$1(AbstractEList<E>).add(E) line: 307
CDOObjectImpl$1(BasicNotifierImpl$EAdapterList<E>).add(E) line: 199
ChangeRecorder.addAdapter(Notifier) line: 631
ChangeRecorder.notifyChanged(Notification) line: 285
ResourceSetImpl(BasicNotifierImpl).eNotify(Notification) line: 380 ResourceSetImpl$ResourcesEList<E>(NotifyingListImpl<E>).dispatchNotification(Notification) line: 267
ResourceSetImpl$ResourcesEList<E>(NotifyingListImpl<E>).addUnique(E) line: 300
ResourceSetImpl$ResourcesEList<E>(AbstractEList<E>).add(E) line: 307
ResourceSetImpl.createResource(URI, String) line: 426
ResourceSetImpl.demandCreateResource(URI) line: 239
ResourceSetImpl.getResource(URI, boolean) line: 391
CDOTransactionImpl(AbstractCDOView).getResource(String, boolean) line: 416
CDOTransactionImpl(AbstractCDOView).newResourceInstance(InternalCDORevision) line: 711
This creation is successfull, and this new r1 instance is put in the objects map.
Later, when trying to put the r1 we created at the beginning in the objects map, we realize that it has already been created, so we throw an illegal state exception.
I just tested a solution in which, inside the cleanObject() method, we do not set the CDOState to CLEAN. This should be done later, once the object has been put to the 'objects' map (actually just after the registerObject() call). It seems to work, but I'll have to determine the impacts of such a fix.
Am I missing something where that could explain my issue?
Do anyone see the possible impacts of the proposed fix?
Best Regards,
Alex
Re: [CDO] "Different object was registered for OID XX" in Native mode [message #902913 is a reply to message #902825] |
Tue, 21 August 2012 02:46   |
Hi Alex,
I could imagine to move some calls around to make the state handler being notified when the object in question is
regeistered with the objects map. Today I'm totally busy with release engineering for Juno SR1 and Kepler M1. In the
meantime, can you please submit a bugzilla and attach a test case that demos your problem? Please extend Abstract
CDOTest and use the test models we provide. Thanks ;-)
Cheers
/Eike
http://www.esc-net.de
Am 20.08.2012 17:57, schrieb Alex Lagarde:
> Hi everyone,
> My Repository contains : - a CDOResource A containing a root r1
> 'objects' map.
> Best Regards,
> Alex
Current Time: Sat Jul 19 04:13:34 EDT 2025
Powered by FUDForum. Page generated in 0.03283 seconds
