Home » Eclipse Projects » NatTable » GlazedLists & EMF(Javabeans is gone...)
GlazedLists & EMF [message #901791] Tue, 14 August 2012 11:21 Go to next message
until now i was using my homebrewn javabean observerpattern;
now i changed to EMF which uses its own patterns;
so when i try to run my old code for nattable,
it runs into an exception which tells:
Couldn't find listener methods for formTest.TestObject
which is pretty simple due the fact that there is no more bean support due EMF.
so, do i still need the glazedlists for internal sorting, grouping etc, or are those lists only for updating the data (which emf does now)?
or does anyone know how i can add the needed features to my EMF classes without much of a hassle...
Thanks in Advance
lumo
Re: GlazedLists & EMF [message #901794 is a reply to message #901791] Tue, 14 August 2012 11:28 Go to previous messageGo to next message
GlazedLists support is an extension to NatTable core. So you can use GlazedLists for sorting, filtering and trees but you don't have to if you find another way. My first steps with NatTable didn't use GlazedLists while I've found out that using them make sorting and filtering much easier. Also the tree functionality is based on GlazedLists.
Dependent on which features of the NatTable you are using it can be quite easy to remove the GlazedLists dependencies. If you are using trees it could become quite difficult.
Greez,
Dirk
Re: GlazedLists & EMF [message #902732 is a reply to message #901794] Mon, 20 August 2012 03:52 Go to previous messageGo to next message
after looking through my code, i'd say i need the glazedlists.
and in the meantime i worked out how to transform the notifications from emf to the needed updates for the lists.
it was tricky but still worth the work.
edit: fixed all problems, now also accessing subobjects is working with EMF FeaturePaths! Very Happy
[Updated on: Mon, 20 August 2012 04:19] by Moderator
Re: GlazedLists & EMF [message #904017 is a reply to message #902732] Mon, 20 August 2012 07:21 Go to previous messageGo to next message
Hi Ludwig,
I am also using an EMF model and want to display the properties in NatTable. How did you transform
the notifications between EMF model and NatTable?
Martin
Ludwig Moser wrote, On 20.08.2012 09:52:
> for the lists.
> my only problem i got left is when the object displayed is not an attribute of the main object
> rather than a subobject on the object with an attribute i want to gain...
Re: GlazedLists & EMF [message #912915 is a reply to message #904017] Fri, 14 September 2012 07:47 Go to previous message
late reply, sorry
i defined an interface:
 * <copyright>
package lumo.ecore.emf;
import java.beans.PropertyChangeEvent;
 * <!-- begin-user-doc -->
 * A representation of the model object '<em><b>Java Bean Support</b></em>'.
 * <!-- end-user-doc -->
 * <p>
 * The following features are supported:
 * <ul>
 *   <li>{@link formTest.JavaBeanSupport#getListeners <em>Listeners</em>}</li>
 * </ul>
 * </p>
 * @see formTest.FormTestPackage#getJavaBeanSupport()
 * @model
 * @generated
public interface JavaBeanSupport extends EObject {
	 * Returns the value of the '<em><b>Listeners</b></em>' attribute list.
	 * The list contents are of type {@link java.beans.PropertyChangeListener}.
	 * <p>
	 * If the meaning of the '<em>Listeners</em>' attribute list isn't clear,
	 * there really should be more of a description here...
	 * </p>
	 * @return the value of the '<em>Listeners</em>' attribute list.
	 * @see formTest.FormTestPackage#getJavaBeanSupport_Listeners()
	 * @model dataType="formTest.PropertyChangeListener"
	 * @generated
	EList<PropertyChangeListener> getListeners();
	 * @model listenerDataType="formTest.PropertyChangeListener"
	 * @generated
	void addPropertyChangeListener(PropertyChangeListener listener);
	 * @generated
	void removePropertyChangeListener(PropertyChangeListener listener);
	 * @model evtDataType="formTest.PropertyChangeEvent"
	 * @generated
	void propertyChange(PropertyChangeEvent evt);
} // JavaBeanSupport
and then implemented it:
import java.beans.PropertyChangeListener;
import java.util.Collection;
import lumo.ecore.emf.JavaBeanSupport;
import org.eclipse.emf.common.notify.Adapter;
import org.eclipse.emf.common.notify.Notification;
import org.eclipse.emf.common.notify.impl.AdapterImpl;
import org.eclipse.emf.common.util.EList;
import org.eclipse.emf.ecore.EClass;
import org.eclipse.emf.ecore.EStructuralFeature;
import org.eclipse.emf.ecore.impl.EObjectImpl;
import org.eclipse.emf.ecore.util.EDataTypeUniqueEList;
import formTest.FormTestPackage;
 * <!-- begin-user-doc --> An implementation of the model object '
 * <em><b>Java Bean Support</b></em>'. <!-- end-user-doc -->
 * <p>
 * The following features are implemented:
 * <ul>
 * <li>{@link formTest.impl.JavaBeanSupportImpl#getListeners <em>Listeners</em>}
 * </li>
 * </ul>
 * </p>
 * @generated
public class JavaBeanSupportImpl extends EObjectImpl implements JavaBeanSupport {
	 * The cached value of the '{@link #getListeners() <em>Listeners</em>}'
	 * attribute list. <!-- begin-user-doc --> <!-- end-user-doc -->
	 * @see #getListeners()
	 * @generated
	 * @ordered
	protected EList<PropertyChangeListener> listeners;
	 * <!-- begin-user-doc --> <!-- end-user-doc -->
	 * @generated NOT
	Adapter adapter = new AdapterImpl() {
		public void notifyChanged(Notification n) {
			System.out
					.println("Notfication received from the data model. Data model has changed!!!");
			System.out.println("n.getFeature().getClass().getSimpleName() = "
					+ n.getFeature().getClass().getSimpleName());
			EStructuralFeature feature = (EStructuralFeature) n.getFeature();
			if (feature == null) {
				return;
			String propertyName = feature.getName();
			// System.out.println("n.getFeature(): "+attr.getName());
			PropertyChangeEvent evt = new PropertyChangeEvent(n.getNotifier(),
					propertyName, n.getOldValue(), n.getNewValue());
			getBean().propertyChange(evt);
	 * @generated
	public JavaBeanSupportImpl() {
		super();
	protected JavaBeanSupport getBean() {
		return this;
	 * @generated
	protected EClass eStaticClass() {
		return FormTestPackage.Literals.JAVA_BEAN_SUPPORT;
	 * @generated
	public EList<PropertyChangeListener> getListeners() {
		if (listeners == null) {
			listeners = new EDataTypeUniqueEList<PropertyChangeListener>(
					PropertyChangeListener.class, this,
					FormTestPackage.JAVA_BEAN_SUPPORT__LISTENERS);
		return listeners;
	 * @generated NOT
	public void addPropertyChangeListener(PropertyChangeListener listener) {
		getListeners().add(listener);
		eAdapters().add(adapter);
		// throw new UnsupportedOperationException();
	 * @generated NOT
	public void removePropertyChangeListener(PropertyChangeListener listener) {
		getListeners().remove(listener);
		eAdapters().remove(adapter);
	 * @generated
	public void propertyChange(PropertyChangeEvent evt) {
		// TODO: implement this method
		// Ensure that you remove @generated or mark it @generated NOT
	 * @generated
	public Object eGet(int featureID, boolean resolve, boolean coreType) {
		switch (featureID) {
		case FormTestPackage.JAVA_BEAN_SUPPORT__LISTENERS:
			return getListeners();
		return super.eGet(featureID, resolve, coreType);
	 * @generated
	@SuppressWarnings("unchecked")
	public void eSet(int featureID, Object newValue) {
			getListeners().clear();
			getListeners().addAll(
					(Collection<? extends PropertyChangeListener>) newValue);
			return;
		super.eSet(featureID, newValue);
	 * @generated
	public void eUnset(int featureID) {
			return;
		super.eUnset(featureID);
	 * @generated
	public boolean eIsSet(int featureID) {
			return listeners != null && !listeners.isEmpty();
		return super.eIsSet(featureID);
	 * @generated
	public String toString() {
		if (eIsProxy())
			return super.toString();
		StringBuffer result = new StringBuffer(super.toString());
		result.append(" (listeners: ");
		result.append(listeners);
		result.append(')');
		return result.toString();
} // JavaBeanSupportImpl
there is some unneeded console log but it should work
let me know if it helped
EDIT: referring to this forum post this solution is not perfect. (but hey, its one!)
http://www.eclipse.org/forums/index.php/m/902757/#msg_902757
[Updated on: Fri, 14 September 2012 07:53] by Moderator
Previous Topic:TreeNatTableExample - single selection on expand/collapse image doesn't work
Next Topic:IDataProvider
Current Time: Sat Jul 19 02:35:25 EDT 2025
Powered by FUDForum. Page generated in 0.04041 seconds
