Home » Archived » BIRT » Calculates with 2 Data Sets(How can calculate a expression from 2 data set?)
Calculates with 2 Data Sets [message #902553] Sat, 18 August 2012 07:27 Go to next message
I have a question.
I have two databases one is access and other is MySql. I use information in tables and grid for each of these tables and using differents datasets, but when i want to create a DATA Cell with a result from 2 datasets from i have a problem, I don't know what can i do?.
My case is:
DataSet1 = Only it has a row with a number. TOTALSALES = 1112
DataSet2 = Only it has a row with a numbre. TOTALCOST = 345
I want show the value --> TOTALSALES - TOTALCOST in a grid, but i don't know if this is possible or impossible. The DATA CELL i would like to name = BENEFITS
BENEFITS = DataSet1.TOTALSALES - DataSet2.TOTALCOST
BENEFITS = 1112 - 345 = 767
Thanks.
(sorry for my english its no good)
[Updated on: Sun, 19 August 2012 08:48] by Moderator
Re: Calculates with 2 Data Sets [message #902861 is a reply to message #902553] Mon, 20 August 2012 14:32 Go to previous messageGo to next message
You could do something like:
data set one table
in a table with ds 1 you could write a onCreate script for the data
filed that displays total sales.
reportContext.setGlobalVariable("TS", this.getValue());
or
this.getRowData().getColumnValue("TOTALSALES"));
do the same for the data set 2 total cost, but use a different variable
name, say TC.
Then below both tables add a data item (No binding needed) with the
expression:
reportContext.getGlobalVariable("TS")/reportContext.getGlobalVariable("TC");
You may want to get TC first and check for a 0 value.
Jason
On 8/18/2012 7:27 AM, JOSE LUIS wrote:
> I have a question.
> My case is:
> name = BENEFITS
> BENEFITS = DataSet1.TOTALSALES - DataSet1.TOTALCOST BENEFITS = 1112 -
> 345 = 767
> Thanks.
Re: Calculates with 2 Data Sets [message #904139 is a reply to message #902861] Mon, 27 August 2012 17:21 Go to previous messageGo to next message
Thanks Jason, this is information what i needed. Kind Regards
Re: Calculates with 2 Data Sets [message #905164 is a reply to message #902861] Wed, 29 August 2012 16:42 Go to previous messageGo to next message
Hello Again,
I have a problem. When data are INTEGER i have no problem, but when data are DECIMAL or MONEY, RESULT is 0 in all case.
Do you know what is it happening?
Kind Regards
Re: Calculates with 2 Data Sets [message #905588 is a reply to message #905164] Thu, 30 August 2012 13:34 Go to previous messageGo to next message
You can try two things. First instead of using the setGlobalVariable
just put an a script in like:
TS=this.getRowData().getColumnValue("TOTALSALES");
Note that there is no var keyword which should make TS available
downstream. So in an expression later you could just use TS/TC;
or
Specify the type to store the variable
importPackage(Packages.java.lang);
var mydbl = new Double(this.getRowData().getColumnValue("TOTALSALES"));
reportContext.setGlobalVariable("TS", mydbl);
Jason
On 8/29/2012 4:42 PM, JOSE LUIS wrote:
> Hello Again,
> Kind Regards
Re: Calculates with 2 Data Sets [message #906195 is a reply to message #905588] Fri, 31 August 2012 16:34 Go to previous messageGo to next message
Thanks for your information, but if I use the first expression
for example --> TS = 4.945,45 and TC = 2800,00
if I apply to get result:
the result is: 4945452800. This expression dosen't sum, this expression joining the numbers like a text. Do you know, what is happening?.
Thanks.
Re: Calculates with 2 Data Sets [message #906215 is a reply to message #906195] Fri, 31 August 2012 17:16 Go to previous messageGo to next message
can you try?
parseFloat(reportContext.getGlobalVariable("TS"))/parseFloat(reportContext.getGlobalVariable("TC"));
Jason
> Thanks.
Re: Calculates with 2 Data Sets [message #906380 is a reply to message #906215] Sat, 01 September 2012 05:34 Go to previous messageGo to next message
Good Morning Jason,
When I used this expression
parseFloat(reportContext.getGlobalVariable("TS"))-parseFloat(reportContext.getGlobalVariable("TC"));
Eclipse give me a error:
Grid (id = 2825):
+ Can not convert the value of NaN to BigDecimal type.
CONVERT_FAILS ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: Can not convert the value of NaN to BigDecimal type.
Do you know what can we do?
Thanks, Kindest regards
Re: Calculates with 2 Data Sets [message #908003 is a reply to message #906380] Tue, 04 September 2012 10:33 Go to previous message
Verify that reportContext.getGlobalVariable("TS") or
reportContext.getGlobalVariable("TC") is not null before you do the
division.
Jason
On 9/1/2012 5:34 AM, JOSE LUIS wrote:
> Good Morning Jason,
> Grid (id = 2825): + Can not convert the value of NaN to BigDecimal type.
Previous Topic:problem in binding data source to a table from BIRT library
Next Topic:apache.commons.io dependency problem
Current Time: Sun Jul 27 16:28:38 EDT 2025
Powered by FUDForum. Page generated in 0.04553 seconds
