Home » Modeling » EMF » Decimal precision for eStructuralFeatures
Re: Decimal precision for eStructuralFeatures [message #902476 is a reply to message #902473] |
Fri, 17 August 2012 16:01   |
AJ,
No, the annotation must be on the EDataType. So you need to define an
EDataType that wraps BigDecimal and put the annotation on that. Easiest
is to write a small schema and look at how that's converted to Ecore.
On 17/08/2012 9:09 PM, AJ wrote:
> Hi Ed,
> Do you mean doing something like this?
> <eStructuralFeatures xsi:type="dict:EAttributeParameter" name="acrPitch">
> <eAnnotations source="descriptor">
> <details key="display_name" value="Pitch"/>
> </eAnnotations>
> <eType xsi:type="ecore:EDataType"
> href="http://www.w3.org/TR/xmlschema-2/#rf-fractionDigits"/>
> </eStructuralFeatures>
> Or, do you mean embed another eAnnotations like this?
> </eAnnotations>
> <eAnnotations
> source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
> <details key="baseType"
> value="http://www.w3.org/TR/xmlschema-2/#rf-fractionDigits"/>
> <details key="value" value="2"/>
> </eAnnotations>
> Thanks!
> On 8/17/12 1:04 AM, Ed Merks wrote:
>> AJ,
>> Yes, with extended metadata annotations on an EDataType you can specify
>> the number of fractional digits as in XML Schema
>> On 17/08/2012 8:39 AM, AJ Ben wrote:
>>> Is it possible declare the eType of an eStructuralFeatures as decimal?
>>> Will this be valid?
>>> name="toControl" eType="ecore:EDataType
>>> http://www.eclipse.org/emf/2003/XMLType#//Decimal">
>>> Also, can one also indicate the precision (e.g. 2 decimals)?
>>> Thanks in advance!
Re: Decimal precision for eStructuralFeatures [message #902500 is a reply to message #902476] |
Fri, 17 August 2012 20:12   |
Ed,
As you suggested, I created a small schema:
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
ecore:nsPrefix="test" ecore:package="test" targetNamespace="test">
<xsd:simpleType ecore:name="ThreeDecimalsType" name="ThreeDecimals_Type">
<xsd:restriction base="xsd:decimal">
<xsd:fractionDigits value="3"/>
</xsd:restriction>
</xsd:simpleType>
</xsd:schema>
And EMF generated an EDataType like this:
<eClassifiers xsi:type="ecore:EDataType" name="ThreeDecimalsType"
instanceClassName="java.math.BigDecimal">
<eAnnotations
<details key="name" value="ThreeDecimals_Type"/>
value="http://www.eclipse.org/emf/2003/XMLType#decimal"/>
<details key="fractionDigits" value="3"/>
</eAnnotations>
</eClassifiers>
However, I am still able to enter more than 3 decimals when I added this
new type to the feature:
name="acrPitch" eType="//ThreeDecimalsType">
</eAnnotations>
I can see that BasicExtendedMetaData::basicGetBaseType() detects the new
type, but neither basicGetFractionDigitsFacet() or
setFractionDigitsFacet() are called.
Did I miss anything else?
Thanks again!
On 8/17/12 1:01 PM, Ed Merks wrote:
> AJ,
>> Hi Ed,
>> </eAnnotations>
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> Thanks!
>>> AJ,
>>>> Will this be valid?
>>>> Thanks in advance!
Re: Decimal precision for eStructuralFeatures [message #902521 is a reply to message #902500] |
Sat, 18 August 2012 01:28   |
AJ,
EObjectValidator validates such things, but only when you invoke the
validator. I'd expect PropertyDescriptor.EDataTypeValueHandler.isValid
to invoke validation. What do you mean by "able to enter"? Via the
properties view?
On 18/08/2012 2:12 AM, AJ wrote:
> Ed,
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:schema>
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> this new type to the feature:
> </eAnnotations>
> new type, but neither basicGetFractionDigitsFacet() or
> Thanks again!
>> AJ,
>>> Hi Ed,
>>> name="acrPitch">
>>> </eAnnotations>
>>> name="acrPitch">
>>> </eAnnotations>
>>> <eAnnotations
>>> </eAnnotations>
>>> Thanks!
>>>> AJ,
>>>> specify
>>>>> decimal?
>>>>> Will this be valid?
>>>>> Thanks in advance!
Current Time: Sun Jul 27 13:44:49 EDT 2025
Powered by FUDForum. Page generated in 0.02929 seconds
