Home » Archived » Buckminster » Updating qualifier for product feature
Updating qualifier for product feature [message #902470] Fri, 17 August 2012 14:37 Go to next message
When I build my product, the product feature does not change, thus between builds the product feature's feature version always stays the same (my qualifier replacement strategy is lastRevision). This causes problem when I run another build and try to update my previous build - since feature versions are the same for build 1 and build 2, there is nothing to update.
To overcome this issue I have a text file in product feature that I update whenever I do release build. This works, but I rather not do this as nightly updates do not work.
Is there a way to update product's feature version with each build?
Alex
Re: Updating qualifier for product feature [message #902735 is a reply to message #902470] Mon, 20 August 2012 04:11 Go to previous messageGo to next message
You should not need to do anything - see http://www.eclipse.org/forums/index.php/mv/msg/148718/467887/#msg_467887
See also http://www.eclipse.org/forums/index.php/mv/msg/268427/768667/#msg_768667 for use when the SCM is Git
Matthew
Re: Updating qualifier for product feature [message #902802 is a reply to message #902735] Mon, 20 August 2012 09:56 Go to previous message
Thanks Matthew, all this time using Buckminster and I didn't know it calculates qualifier based on its dependencies.
Previous Topic:Error in building fragment project
Next Topic:Resolution problems with Indigo: NPE in EclipsePlatformReaderType.getBestPlugin
Current Time: Thu Jul 24 22:33:36 EDT 2025
Powered by FUDForum. Page generated in 0.26237 seconds
