Home » Eclipse Projects » Virgo » Debugging boot delegation
Debugging boot delegation [message #902449] Fri, 17 August 2012 11:57 Go to next message
In order to muck about with the ClassLoader to do some stuff with OSGI and RMI we've implemented our own RMIClassLoaderSpi, copied the resultant jar to lib/, added its package to org.osgi.framework.bootdelegation in java6-server.profile and are starting virgo with a -D setting java.rmi.server.RMIClassLoaderSpi so that it uses our own version.
This works great - except in one of my machines where it doesn't and the class is not available to the system at runtime (e.g. Class.forName()).
My question is, are there any tips available regarding how I can debug this? For example, is there a way of finding out what packages are actually being made available by the bootdelegation directive?
Thanks in advance,
Dan.
Re: Debugging boot delegation [message #902450 is a reply to message #902449] Fri, 17 August 2012 12:01 Go to previous messageGo to next message
Have a look at the commands available in the telnet shell. Their are two shells, one for the kernel region and one for the user region, you will need to enable them with their respective configs. In the Virgo Kernel and above their are some extra classloading commands that could help you, just type help to see what else is available.
Chris.
Re: Debugging boot delegation [message #902531 is a reply to message #902449] Sat, 18 August 2012 04:04 Go to previous messageGo to next message
I have explored this line of enquiry but wasn't able to find the relevant commands or really understand the output of the ones I tried. Would you be able to give me one further hint?
Thanks for the reply,
Dan.
Re: Debugging boot delegation [message #902899 is a reply to message #902531] Mon, 20 August 2012 21:26 Go to previous messageGo to next message
We have a documentation on the three classloading commands in our user guide, starting with this one. The other two are right below it.
Hope that helps,
Bobby
Re: Debugging boot delegation [message #903061 is a reply to message #902899] Tue, 21 August 2012 15:08 Go to previous message
Thanks, I also found Eclipse support for this kind of debugging in the server settings, 'Bundle Overview' tab.
Re: Debugging boot delegation [message #903695 is a reply to message #902531] Mon, 20 August 2012 21:26 Go to previous message
We have a documentation on the three classloading commands in our user guide, starting with http://www.eclipse.org/virgo/documentation/virgo-documentation-3.5.0.RELEASE/docs/virgo-user-guide/htmlsingle/virgo-user-guide.html#admin-shell-cl-clhas. The other two are right below it.
Hope that helps,
Bobby
Previous Topic:Roadmap for Virgo 3.6 ?
Next Topic:Re: Debugging boot delegation
Current Time: Fri Jul 25 08:34:52 EDT 2025
Powered by FUDForum. Page generated in 0.08375 seconds
