Home » Archived » BIRT » Change BIRT Source(How to Change BIRT Source and Repack jars again)
Change BIRT Source [message #901518] Mon, 13 August 2012 04:39 Go to next message
In order to solve a bug I need to change the addSliceLabel() method in BIRT's source.
I reported the bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=386399, but it is going slow and we need to fix it now.
There is some tutorial describing how to change the birt's source and generate the jars again?
Thank you
Re: Change BIRT Source [message #901634 is a reply to message #901518] Mon, 13 August 2012 13:15 Go to previous messageGo to next message
Ricardo
Take a look at this link:
http://wiki.eclipse.org/BIRT/FAQ/Birt_Project#Q:_How_do_I_build_BIRT.3F
Jason
> BIRT's source.
> Thank you
Re: Change BIRT Source [message #902347 is a reply to message #901634] Fri, 17 August 2012 04:43 Go to previous messageGo to next message
Thank you Jason,
Just to share my solution.
I downloaded the BIRT sources from GIT through eclipse (all steps described in Jason's link). Had to Add to eclipse some aditional features through "Install new Sofware" option, for the project to compile.
Searched for the class that I wanted to update, PieRenderer.java located in the project "org.eclipse.birt.chart.engine.extension", did the code change and after built that project using Ant (BuildChartEngineExtension.xml)
Installed the generated jar in our maven repository.
Updated the pom.xml to include that jar, below:
<dependency>
<groupId>org.eclipse.birt</groupId>
<artifactId>org.eclipse.birt.runtime</artifactId>
<version>3.7.2.v20120214-1408</version>
<exclusions>
<exclusion>
<artifactId>org.eclipse.birt.chart.extension</artifactId>
<groupId>org.eclipse.birt.chart.extension.render</groupId>
</exclusion>
</exclusions>
</dependency>
<dependency>
<groupId>org.eclipse.birt.chart.engine</groupId>
<artifactId>org.eclipse.birt.chart.engine.extension</artifactId>
<version>4.2.0</version>
</dependency>
[Updated on: Fri, 17 August 2012 04:44] by Moderator
Re: Change BIRT Source [message #902422 is a reply to message #902347] Fri, 17 August 2012 10:24 Go to previous message
Thanks for the update.
Jason
On 8/17/2012 4:43 AM, Ricardo Rodrigues wrote:
> Thank you Jason,
> change and after ran that project using Ant (BuildChartEngineExtension.xml)
> <dependency>
> <exclusions>
> <exclusion>
> </exclusion>
> </exclusions>
> </dependency>
> <dependency>
> </dependency>
Previous Topic:Grid Display
Next Topic:BIRT CHART
Current Time: Sat Jul 26 03:59:31 EDT 2025
Powered by FUDForum. Page generated in 0.28234 seconds
