Home » Eclipse Projects » Virgo » Occasional start-up failure due to synchronisation in Virgo kernel
Occasional start-up failure due to synchronisation in Virgo kernel [message #894823] Tue, 10 July 2012 12:24 Go to next message
While using Virgo 2.1.1, my application occasionally (50/50) fails to start. I'm not sure of my interpretation of the issue, but it appears to me to be due to two "region-dm" threads, the 'first' of which is waiting on a ConcurrentHashMap owned by the 'second' which is monitoring because of the first. The map is classNameLocks in ClasspathManager, synchronised at line 510. The monitor is KernelBundleClassLoader.checkCerts, line 933. Relevant stack traces follow, please let me know what additional information I can provide:
Thread [region-dm-10] (Suspended)
	owns: Object  (id=163)
	owns: KernelBundleClassLoader  (id=154)
		waited by: Thread [region-dm-12] (Suspended)
		waited by: Thread [start-signalling-2] (Suspended)
	waiting for: HashMap<K,V>  (id=162)
	Object.wait(long) line: not available [native method]
	HashMap<K,V>(Object).wait() line: 503
	ClasspathManager.lockClassName(String) line: 510
	ClasspathManager.findLocalClass_LockClassName(String, ClassLoadingStatsHook[]) line: 458
	ClasspathManager.findLocalClass(String) line: 447
	KernelBundleClassLoader(DefaultClassLoader).findLocalClass(String) line: 216
	BundleLoader.findLocalClass(String) line: 393
	BundleLoader.findClassInternal(String, boolean, ClassLoader) line: 469
	BundleLoader.findClass(String, boolean) line: 422
	BundleLoader.findClass(String) line: 410
	KernelBundleClassLoader(DefaultClassLoader).loadClass(String, boolean) line: 107
	KernelBundleClassLoader.loadClass(String, boolean) line: 135
	KernelBundleClassLoader(ClassLoader).loadClass(String) line: 356
	ClassLoader.defineClass1(String, byte[], int, int, ProtectionDomain, String) line: not available [native method]
	KernelBundleClassLoader(ClassLoader).defineClass(String, byte[], int, int, ProtectionDomain) line: 791
	KernelBundleClassLoader(DefaultClassLoader).defineClass(String, byte[], ClasspathEntry, BundleEntry) line: 188
	KernelBundleClassLoader.defineClass(String, byte[], ClasspathEntry, BundleEntry) line: 239
	ClasspathManager.defineClass(String, byte[], ClasspathEntry, BundleEntry, ClassLoadingStatsHook[]) line: 580
	ClasspathManager.findClassImpl(String, ClasspathEntry, ClassLoadingStatsHook[]) line: 550
	ClasspathManager.findLocalClassImpl(String, ClassLoadingStatsHook[]) line: 481
	ClasspathManager.findLocalClass_LockClassName(String, ClassLoadingStatsHook[]) line: 460
	BundleLoader.loadClass(String) line: 338
	BundleHost.loadClass(String, boolean) line: 232
	BundleHost(AbstractBundle).loadClass(String) line: 1197
	BundleDelegatingClassLoader.findClass(String) line: 99
	BundleDelegatingClassLoader.loadClass(String, boolean) line: 156
	BundleDelegatingClassLoader(ClassLoader).loadClass(String) line: 356
	ClassUtils.forName(String, ClassLoader) line: 257
	RootBeanDefinition(AbstractBeanDefinition).resolveBeanClass(ClassLoader) line: 408
	DefaultListableBeanFactory(AbstractBeanFactory).doResolveBeanClass(RootBeanDefinition, Class...) line: 1271
	DefaultListableBeanFactory(AbstractBeanFactory).resolveBeanClass(RootBeanDefinition, String, Class...) line: 1242
	DefaultListableBeanFactory(AbstractAutowireCapableBeanFactory).predictBeanType(String, RootBeanDefinition, Class[]) line: 576
	DefaultListableBeanFactory(AbstractBeanFactory).isFactoryBean(String, RootBeanDefinition) line: 1319
	DefaultListableBeanFactory.getBeanNamesForType(Class, boolean, boolean) line: 315
	OsgiBundleXmlApplicationContext(AbstractDelegatedExecutionApplicationContext).invokeBeanFactoryPostProcessors(ConfigurableListableBeanFactory, Class, Class) line: 424
	OsgiBundleXmlApplicationContext(AbstractDelegatedExecutionApplicationContext).invokeBeanFactoryPostProcessors(ConfigurableListableBeanFactory) line: 395
	AbstractDelegatedExecutionApplicationContext$3.run() line: 281
	PrivilegedUtils.executeWithCustomTCCL(ClassLoader, PrivilegedUtils$UnprivilegedExecution) line: 85
	OsgiBundleXmlApplicationContext(AbstractDelegatedExecutionApplicationContext).startRefresh() line: 247
	DependencyWaiterApplicationContextExecutor.stageOne() line: 214
	DependencyWaiterApplicationContextExecutor.refresh() line: 169
	OsgiBundleXmlApplicationContext(AbstractDelegatedExecutionApplicationContext).refresh() line: 175
	ContextLoaderListener$2.run() line: 716
	ContextPropagatingTaskExecutor$2.run() line: 95
	ThreadPoolExecutor.runWorker(ThreadPoolExecutor$Worker) line: 1110
	ThreadPoolExecutor$Worker.run() line: 603
	Thread.run() line: 722
	owns: ConcurrentHashMap<K,V>  (id=155)
	waiting for: KernelBundleClassLoader  (id=154)
	KernelBundleClassLoader(ClassLoader).checkCerts(String, CodeSource) line: 933
	KernelBundleClassLoader(ClassLoader).preDefineClass(String, ProtectionDomain) line: 657
	KernelBundleClassLoader(ClassLoader).defineClass(String, byte[], int, int, ProtectionDomain) line: 785
	SingleSourcePackage.loadClass(String) line: 33
	BundleLoader.findClassInternal(String, boolean, ClassLoader) line: 457
	ClassUtils.resolveClassName(String, ClassLoader) line: 290
	ClassArrayEditor.setAsText(String) line: 68
	TypeConverterDelegate.doConvertTextValue(Object, String, PropertyEditor) line: 416
	TypeConverterDelegate.doConvertValue(Object, Object, Class<?>, PropertyEditor) line: 388
	TypeConverterDelegate.convertIfNecessary(String, Object, Object, Class<T>, TypeDescriptor) line: 157
	BeanWrapperImpl.convertIfNecessary(String, Object, Object, Class<?>, TypeDescriptor) line: 447
	BeanWrapperImpl.convertForProperty(String, Object, Object, PropertyDescriptor) line: 499
	BeanWrapperImpl.convertForProperty(Object, String) line: 493
	DefaultListableBeanFactory(AbstractAutowireCapableBeanFactory).convertForProperty(Object, String, BeanWrapper, TypeConverter) line: 1371
	DefaultListableBeanFactory(AbstractAutowireCapableBeanFactory).applyPropertyValues(String, BeanDefinition, BeanWrapper, PropertyValues) line: 1330
	DefaultListableBeanFactory(AbstractAutowireCapableBeanFactory).populateBean(String, AbstractBeanDefinition, BeanWrapper) line: 1086
	DefaultListableBeanFactory(AbstractAutowireCapableBeanFactory).doCreateBean(String, RootBeanDefinition, Object[]) line: 517
	DefaultListableBeanFactory(AbstractAutowireCapableBeanFactory).createBean(String, RootBeanDefinition, Object[]) line: 456
	AbstractBeanFactory$1.getObject() line: 291
	DefaultListableBeanFactory(DefaultSingletonBeanRegistry).getSingleton(String, ObjectFactory) line: 222
	DefaultListableBeanFactory(AbstractBeanFactory).doGetBean(String, Class<T>, Object[], boolean) line: 288
	DefaultListableBeanFactory(AbstractBeanFactory).getBean(String) line: 190
	MandatoryImporterDependencyFactory.getServiceDependencies(BundleContext, ConfigurableListableBeanFactory) line: 63
	DependencyServiceManager.doFindDependencies() line: 272
	DependencyServiceManager.access$700(DependencyServiceManager) line: 40
	DependencyServiceManager$1.run() line: 213
	PrivilegedUtils.executeWithCustomTCCL(ClassLoader, PrivilegedUtils$UnprivilegedThrowableExecution) line: 124
	DependencyServiceManager.findServiceDependencies() line: 209
	DependencyWaiterApplicationContextExecutor.stageOne() line: 239
Re: Occasional start-up failure due to synchronisation in Virgo kernel [message #896123 is a reply to message #894823] Tue, 17 July 2012 06:49 Go to previous messageGo to next message
That deadlock appears to be outside the control of Virgo. It sounds similar to Equinox bug 212262. See comment 16 for a possible workaround.
You should probably plan to upgrade to Virgo 3.5.0 to pick up all the latest Equinox fixes.
[Updated on: Tue, 17 July 2012 06:50] by Moderator
Re: Occasional start-up failure due to synchronisation in Virgo kernel [message #896464 is a reply to message #896123] Wed, 18 July 2012 09:05 Go to previous messageGo to next message
Thanks Glyn!
I will report back if I'm able to implement a workaround.
Dan.
Re: Occasional start-up failure due to synchronisation in Virgo kernel [message #896866 is a reply to message #896464] Fri, 20 July 2012 03:57 Go to previous messageGo to next message
Ok, please let us know either way.
Re: Occasional start-up failure due to synchronisation in Virgo kernel [message #901836 is a reply to message #896866] Tue, 14 August 2012 13:51 Go to previous messageGo to next message
Hi again,
I made the upgrade to 3.5 but the symptoms remain, but I haven't had the time to figure out if the cause is still the same. I'll report back again when I have such.
Dan.
Re: Occasional start-up failure due to synchronisation in Virgo kernel [message #902340 is a reply to message #901836] Fri, 17 August 2012 03:56 Go to previous message
Thanks Dan.
Previous Topic:cxf_dosgi running under virgo
Next Topic:Roadmap for Virgo 3.6 ?
Current Time: Sat Jul 26 11:02:20 EDT 2025
Powered by FUDForum. Page generated in 0.05172 seconds
