Home » Modeling » GMF (Graphical Modeling Framework) » Notation Elements on Diagram Initalization
Notation Elements on Diagram Initalization [message #901052] Thu, 09 August 2012 10:27 Go to next message
Iam trying to add some elements when diagram is created. But those elements are not added/shown in the diagram. Actually elements are getting added to model but not to the notation.
In XXXDiagramUtil class, in createDiagram method iam creating new nodes to the diagram using ViewService.createNode(diagram, element,...
Elements are added to model but not to the notation. How to add notation elements whendiagram is created
Sarath
Re: Notation Elements on Diagram Initalization [message #901168 is a reply to message #901052] Fri, 10 August 2012 04:06 Go to previous messageGo to next message
did you try out this request: http://publib.boulder.ibm.com/infocenter/rsmhelp/v7r0m0/index.jsp?topic=/org.eclipse.gmf.doc/reference/api/runtime/org/eclipse/gmf/runtime/diagram/ui/requests/CreateUnspecifiedTypeRequest.html ? It executes the same code that is executed when creating a model element via the palette.
Ralph
Re: Notation Elements on Diagram Initalization [message #902339 is a reply to message #901168] Fri, 17 August 2012 03:40 Go to previous message
There was problem in my model,graph that is why ViewService.createNode is not generating notation element. After fixing errors in my model,graph,map and regenerating code....it started working....ViewService.createNode is creating node/view and diagram is shown with default elements....
model = createInitialModel();
attachModelToResource(model, diagramResource);
CustomElement element ......
model.getElements().add(element);
Diagram diagram = ViewService.createDiagram(model,
XXXX.MODEL_ID,
XXXXX.DIAGRAM_PREFERENCES_HINT);
Node elementNode = ViewService.createNode(diagram, element,
XXXXX.getType(XXXXX.VISUAL_ID),
Bounds bounds = NotationFactory.eINSTANCE.createBounds();
bounds.setX(10);
bounds.setY(20);
elementNode.setLayoutConstraint(bounds);
Sarath
Previous Topic:problem in creating a new editor in Eclipse Application
Next Topic:Containment Feature owned by Domain Meta Element
Current Time: Sat Jul 19 00:33:57 EDT 2025
Powered by FUDForum. Page generated in 0.04634 seconds
