Home » Eclipse Projects » WindowBuilder » How add restriction to delete a component
Re: How add restriction to delete a component [message #902273 is a reply to message #902270] |
Thu, 16 August 2012 13:41   |
IIRC "isComponentType" is available only for flow/simple containers.
And if there is any error in "canDelete" script, we consider this as "false".
In other scripts you have only ReflectionUtils class.
But actually all this can be done using ReflectionUtils, see org.eclipse.wb.internal.core.model.generic.ContainerObjectValidators.DEF_functions
private static final String DEF_functions = StringUtils.join(new String[]{
"def isModelType(model, c) {",
" if (c is String) {",
" return ReflectionUtils.isSuccessorOf((Class) model.description.componentClass, c);",
" } else {",
" return c.isAssignableFrom(model.description.componentClass);",
"def isSuccessorOf(o, c) {",
" return ReflectionUtils.isSuccessorOf(o, c);",
" } else {",
" return o != null && c.isAssignableFrom(o.getClass());",
"def isComponentType(c) {",
" return isModelType(component, c);",
"def isReferenceType(c) {",
" return isModelType(reference, c);",
"def isContainerType(c) {",
" return isModelType(container, c);",
"def isContainerThis() {",
" return isSuccessorOf(container.creationSupport, "
+ "'org.eclipse.wb.internal.core.model.creation.ThisCreationSupport');",
"};",}, "\n");
[Updated on: Thu, 16 August 2012 13:41] by Moderator
Current Time: Tue Sep 16 21:47:09 EDT 2025
Powered by FUDForum. Page generated in 0.04348 seconds
