Home » Modeling » EMF » [EMF-Databinding] Observe addition/removal changes in multi-value feature of a multi-value feature
[EMF-Databinding] Observe addition/removal changes in multi-value feature of a multi-value feature [message #902114] Wed, 15 August 2012 18:38 Go to next message
Me again... :S
We want to observe element additions/removals from a list of a list of objects (like a double-nested multi-value feature)
We have a Model instance, this one has a multi-value feature, the objects from this feature was shown in a table. They have another multi-value feature inside that I want to observe.
Wrong code:
WritableValue writable = new WritableValue();
writable.setValue(model);
IObservableList observableSubElementList = EMFProperties.list(ModelPackage.Literals.MODEL__SUBELEMENTS).observeDetail(writable);
ObservableListContentProvider ocp = new ObservableListContentProvider();
tableViewer.setContentProvider(ocp);
table.setInput(observableSubElementList);
//One wrong possibility to observe changes in the SubList:
IObservableList observableSubSubElementList = EMFProperties.value(ModelPackage.Literals.SUBELEMENT__SUBSUBELEMENTS).observeDetail(observableSubElementList);
observableSubSubElementList.addListChangeListener(new IListChangeListener() {
    public void handleListChange(ListChangeEvent event) {
          //Do something
//Another wrong possibility to observe changes in the SubList:
IObservableList observableSubSubElementMap = EMFProperties.value(ModelPackage.Literals.SUBELEMENT__SUBSUBELEMENTS).observeDetail(ocp.getKnownElements());
observablePermissionList.addMapChangeListener(new IMapChangeListener() {
          //Do something
The wrong code only observe changes if one list is replaced by other list (other Java object). It does not observe to the subelement additions or removals in any list.
I think we have to use not ObservableList/Map.value but ObservableList/Map.list:
IObservableList observableSubSubElementList = EMFProperties.list(ModelPackage.Literals.SUBELEMENT__SUBSUBELEMENTS) -> xxxxx -> observableSubElementList
xxxxx can be a method or a group of methods that I cannot find.
Any idea? Or maybe is it not possible?
[Updated on: Wed, 15 August 2012 18:41] by Moderator
Re: [EMF-Databinding] Observe addition/removal changes in multi-value feature of a multi-value featu [message #902149 is a reply to message #902114] Thu, 16 August 2012 02:51 Go to previous messageGo to next message
What you want to do is not supported, the only thing we have since the
last release is that you can observe an index inside a list but this
would mean your first list is has a fixed amount of items.
Tom
Am 16.08.12 00:38, schrieb Paco Blanco:
> Me again... :S
> Wrong code:
> @Override
> //Do something
> @Override
> //Do something
> additions or removals in the lists.
Re: [EMF-Databinding] Observe addition/removal changes in multi-value feature of a multi-value featu [message #902187 is a reply to message #902149] Thu, 16 August 2012 05:26 Go to previous messageGo to next message
Thank for your answer, Tom.
Can you say to me how to do "you can observe an index inside a list but this would mean your first list is has a fixed amount of items"? (with simple code snippet is enough Razz)
BTW, my aprroach to the topic problem is:
private Map<Object, IObservableList> observablePermissionMap = new HashMap<Object,IObservableList>();
method:
observableSubElementList.addListChangeListener(new IListChangeListener() {
    for(final ListDiffEntry entry : event.diff.getDifferences()) {
      if(entry.isAddition()) {
        addObservableToMap((MySubElementClass) entry.getElement());
      } else if(observablePermissionMap.containsKey(entry.getElement())){
        observableList observable = observablePermissionMap.get(entry.getElement());
        observable.dispose();
        observablePermissionMap.remove(entry.getElement());
for(final Object objectToObserve : observableSubElementList) {
  if(!observablePermissionMap.containsKey(objectToObserve)) {
    addObservableToMap((MySubElementClass) objectToObserve);
end method
private void addObservableToMap(final MySubElementClass objectToObserve) {
  IObservableList observable = EMFProperties.list(ModelPackage.Literals.SUBELEMENT__SUBSUBELEMENTS).observe(objectToObserve);
  observable.addChangeListener(new IChangeListener() {
    public void handleChange(ChangeEvent event) {
      //Do something, in my case:
      table.getTableViewer().update(objectToObserve, columnProperties);
  observablePermissionMap.put(objectToObserve, observable);
[Updated on: Fri, 24 August 2012 09:23] by Moderator
Re: [EMF-Databinding] Observe addition/removal changes in multi-value feature of a multi-value featu [message #902190 is a reply to message #902187] Thu, 16 August 2012 05:32 Go to previous message
http://tomsondev.bestsolution.at/2011/05/06/interesting-new-feature-in-emf-databinding/
Tom
Am 16.08.12 11:26, schrieb Paco Blanco:
> Thank for your answer, Tom. Can you say to me how to do "you can observe
> fixed amount of items"? (with simple code snippet is enough :p)
> BTW, my aprroach to this problem is:
> method:
> .... WritableValue writable = new WritableValue();
> @Override
> addObserverToMap((MySubSubElementClass) entry.getElement());
> addObserveToUserPermission((MySubSubElementClass) objectToObserve);
> ... end method
> private void addObserveToMap(final MySubSubElementClass objectToObserve) {
> @Override
> columnProperties);
Previous Topic:problem converting uml file to ecore and genmodel file
Next Topic:Duplicate overloaded property
Current Time: Sat Jul 26 11:40:46 EDT 2025
Powered by FUDForum. Page generated in 0.03778 seconds
