Unfinished Report [message #902031] |
Wed, 15 August 2012 10:59  |
Good evening,
I am currently having problems when displaying a report that used to work. The report uses a custom ODA data source that accesses a database. Instead of showing a report consisting of several pages containing data read from the database, what I see is just the usual icons that come when using the _frameset command and a subsequent line that is 'Showing page 1 of'. I have tried with different browsers, among others IE9 and Firefox.
Usually, when there are problems accessing the database, the report is not displayed but in the browser window or either in a pop-up there comes some complaint about BIRT not being able to deal with a certain element in the report which usually is a table connected to a query. But currently there is no such response.
It seems as if the browser waits for the report to finish without getting into any timeout. Does anybody have a suggestion what the reason for such a behaviour can be?
Thanks & regards,
Juliane.
Re: Unfinished Report [message #903220 is a reply to message #902256] |
Wed, 22 August 2012 10:58  |
Hi Jason,
finally, we had a chance to look at the very BIRT engine that fails, and it appeared that the problem was caused by some bad files that contain all zero bytes, among others, some JavaScript an CSS stuff. So, no wonder it refuses to work properly.
Thanks for your help,
Juliane.
FUDForum. Page generated in 0.05676 seconds
