Home » Eclipse Projects » Rich Client Platform (RCP) » Common Navigator Framework(Pop-up Menus in Common Navigator Framework)
Common Navigator Framework [message #901695] Tue, 14 August 2012 03:59 Go to next message
I am using Eclipse's common navigator framework. For the pop-up menu within CNF I set the attribute allow-platformcontribution to false. Yet I am not able to remove the pop-up option for Cut, Copy, Paste and Team. How to set them off?
Priyank Thakkar
Re: Common Navigator Framework [message #902016 is a reply to message #901695] Wed, 15 August 2012 09:55 Go to previous message
You just solved my problem!
For me it works like this and I can see only the contributions I made.
If you don't want the edit you can remove for example :
         <insertionPoint
               name="group.edit"
               separator="true">
         </insertionPoint>
   <viewer
         viewerId="mycustomnavid">
      <popupMenu
            allowsPlatformContributions="false"
            id="mycustomnavid#PopupMenu">
         <insertionPoint
               name="group.new">
         </insertionPoint>
         <insertionPoint
               name="group.open"
               separator="true">
         </insertionPoint>
         <insertionPoint
               name="group.openWith">
         </insertionPoint>
         <insertionPoint
               name="group.edit"
               separator="true">
         </insertionPoint>
         <insertionPoint
               name="group.reorganize">
         </insertionPoint>
         <insertionPoint
               name="group.port"
               separator="true">
         </insertionPoint>
         <insertionPoint
               name="group.build"
               separator="true">
         </insertionPoint>
         <insertionPoint
               name="group.generate"
               separator="true">
         </insertionPoint>
         <insertionPoint
               name="group.search"
               separator="true">
         </insertionPoint>
         <insertionPoint
               name="additions"
               separator="true">
         </insertionPoint>
         <insertionPoint
               name="group.properties"
               separator="true">
         </insertionPoint>
      </popupMenu>
   </viewer>
[Updated on: Wed, 15 August 2012 09:58] by Moderator
Previous Topic:multiple column table header
Next Topic:Unwanted menu contributions CNF
Current Time: Fri Jul 18 15:37:55 EDT 2025
Powered by FUDForum. Page generated in 0.07406 seconds
