Home » Eclipse Projects » Eclipse Platform » Help with template creation
Help with template creation [message #901342] Fri, 10 August 2012 19:35 Go to next message
So if I declare a private member such as
private MyObject test;
I want to create a template that will generate code in the following format
public MyObject retrieveAllMyObjects() {
    return test.findAll();
I have been messing around with the templates but I can't even figure out how to activate the templates. when I do the Ctrl+Space i just get no template proposals message
public ${return_type} retrieveAll${field}s() {
Obviously this is just a starting point, i was just trying to see if i could get eclipse to generate this and then I would go from there, but no such luck. My template doesn't show up anywhere. The context im using is "Java Type Members" what am I doing wrong??
Re: Help with template creation [message #901409 is a reply to message #901342] Sat, 11 August 2012 18:37 Go to previous messageGo to next message
Reading through the variables specification, I think this one is more close :
public ${t:elemType(x)} retrieveAll${x:field}s() {
Also, the categories that content assist provides are configured in Java > Editor > Content Assist > Advanced.
However, I could not get this working either (new the template is not listed in the proposal list)
Vlad
[Updated on: Sun, 12 August 2012 04:47] by Moderator
Re: Help with template creation [message #901549 is a reply to message #901342] Mon, 13 August 2012 06:42 Go to previous messageGo to next message
> format
You need to type at least one character to get templates proposals.
Dani
Re: Help with template creation [message #901606 is a reply to message #901342] Mon, 13 August 2012 12:11 Go to previous messageGo to next message
Ok so i was able to get my code template to work only if i edited one of the existing templates in the system to use my code. I took the "private_static_method" stock template and put my code in and it worked. but if I create a new template with the same exact configuration it does not appear. does anyone know if you have to do something special to get new templates to register in eclipse so they can be used?
Re: Help with template creation [message #901610 is a reply to message #901606] Mon, 13 August 2012 12:20 Go to previous messageGo to next message
nevermind I got it working, thanks guys for the help.
Re: Help with template creation [message #901971 is a reply to message #901610] Wed, 15 August 2012 07:17 Go to previous message
Can you post your results for reference ?
Vlad
Previous Topic:Change Event for IContentDescriber
Next Topic:Relationship between code and architecture
Current Time: Sat Jul 26 21:19:22 EDT 2025
Powered by FUDForum. Page generated in 0.03979 seconds
