Home » Archived » EPF » Standard page for the published website
Standard page for the published website [message #901743] Tue, 14 August 2012 08:45 Go to next message
Hi, I'm currently working on a simple method plug-in. In the custom categories, I defined a view and added some content elements. When I publish the method plug-in, everything works fine (no errors or warnings).
What bothers me is that I always first see a blank page. Please see the attached screenshot. Only if I click on "My View", the content and the menu appear.
I couldn't find any useful option to set the default page when opening from the Publishing Options page. Any help is welcome. Thanks.
  • Attachment: 1.png
    (Size: 105.78KB, Downloaded 493 times)
[Updated on: Tue, 14 August 2012 08:46] by Moderator
Re: Standard page for the published website [message #901887 is a reply to message #901743] Tue, 14 August 2012 17:36 Go to previous messageGo to next message
Did you set the My View as the default view for the configuration? It is an option on the View page of the Configuration setup.
Re: Standard page for the published website [message #901941 is a reply to message #901887] Wed, 15 August 2012 04:32 Go to previous messageGo to next message
hi Flavelle, yes, I checked that My View is set as the default view for the custom configuration. The most weird thing is that I have to click on it once to make all the contents visible in the published page...
Re: Standard page for the published website [message #901997 is a reply to message #901941] Wed, 15 August 2012 08:50 Go to previous messageGo to next message
I'd need to see your setup - specifically how you have setup your configuration and the categories that you are using in the view - in order to be able to take a look. Sometimes fresh eyes see something obvious.
Sorry that I can't help more.
Re: Standard page for the published website [message #902352 is a reply to message #901997] Fri, 17 August 2012 05:10 Go to previous message
I think this has nothing to do with my method plugin or configuration. Until now, I used Chrome to view the published website.
I just opened it in Internet Explorer 9 and I first got the warning that some contents were blocked. After clicking on "Allow blocked contents" in IE, the published website appears and the contents are visible. Google Chrome does not say anything about some blocked contents but doesn't show the page correctly.
In the Opera browser the EPF published website does not work at all...
Previous Topic:EPF Composer on Windows 7 Professional 64 bit
Next Topic:New OpenUP library plug-in
Current Time: Sat Jul 26 08:03:48 EDT 2025
Powered by FUDForum. Page generated in 0.11357 seconds
