Home » Archived » XML Schema Definition (XSD) » Adding XSD to Catalog which includes and imports XSD
Adding XSD to Catalog which includes and imports XSD [message #901837] Tue, 14 August 2012 14:00 Go to next message
i want to add an XSD which imports and includes other XSD files to the XSD Catalog with Juno.
The XSD looks like:
<xsd:schema elementFormDefault="qualified" attributeFormDefault="unqualified"
	xmlns="http://www.eclipse.org/spec/BPMN/20100524/MODEL"
	xmlns:xsd="http://www.eclipse.org/2001/XMLSchema"
	xmlns:bpmndi="http://www.eclipse.org/spec/BPMN/20100524/DI"
	targetNamespace="http://www.eclipse.org/spec/BPMN/20100524/MODEL">
	<xsd:import namespace="http://www.eclipse.org/spec/BPMN/20100524/DI" schemaLocation="BPMNDI.xsd"/>
	<xsd:include schemaLocation="Semantic.xsd"/>
these files are located in the same directory than the XSD referencing them.
Is this possible with Eclipse?
The issue is that validation of XML files fails...
I added the "root" XSD with key type "Schema location" and key "http://www.eclipse.org/spec/BPMN/20100524/MODEL"
sh**, i can not post links apart from links to eclipse.org... Sad
Re: Adding XSD to Catalog which includes and imports XSD [message #901865 is a reply to message #901837] Tue, 14 August 2012 15:37 Go to previous messageGo to next message
Chris,
Comments below.
On 14/08/2012 8:00 PM, Chris Joelly wrote:
> Hello,
The catalog is something supported by WTP, so I can't really answer
questions about that...
> The XSD looks like:
> <xsd:import
> them.
That should just work without a catalog. Any relative URIs should be
resolved against the absolute URI of the document containing it, so it
should expect to find these in the same folder.
Does the schema itself validate?
Sounds like a WTP question.
Re: Adding XSD to Catalog which includes and imports XSD [message #901975 is a reply to message #901865] Wed, 15 August 2012 07:38 Go to previous message
Hello Ed,
thanks for your reply.
Ed Merks wrote on Tue, 14 August 2012 15:37
> The XSD looks like:
> <xsd:import
> them.
the thing not clear to me yet is:
on the web these files are at http://www.eclipse.org/spec/BPMN/20100501/, but the URL in the files prefixes with http://www.eclipse.org/spec/BPMN/20100524/MODEL. So i dont know if Eclipse can find and validate XML files build against these schema files will work. Thats why i thought adding them to the catalog. But i dont know the difference between the key types "Schema location" and "Namespace name" when adding a schema file to the catalog. but as u mentioned already, i will ask on WTP forum.
if i open the BPMN20.xsd from a local folder which contains all other referenced XSD files and Validate it, then Eclipse does not complain about it...
ok. thanks for the hint. unfortunately most of the time i dont know what forum is best to ask questions about Eclipse, therefore long time i avoided asking. But as it is simply not possible to solve everything by myself... i just posted here Smile
Chris
this link posting rule is soo annoying... Sad replace www.eclipse.org with the OMGs .org url if there is a need to use them...
Previous Topic:org.eclipse.xsd.XSDSchema
Next Topic:Maven properties and XML in Eclipse
Current Time: Sat Jul 26 10:52:36 EDT 2025
Powered by FUDForum. Page generated in 0.26611 seconds
