Re: Adding XSD to Catalog which includes and imports XSD [message #901975 is a reply to message #901865] |
Wed, 15 August 2012 07:38  |
Hello Ed,
thanks for your reply.
Ed Merks wrote on Tue, 14 August 2012 15:37
> The XSD looks like:
> <xsd:schema elementFormDefault="qualified"
> attributeFormDefault="unqualified"
> xmlns="http://www.eclipse.org/spec/BPMN/20100524/MODEL"
> xmlns:xsd="http://www.eclipse.org/2001/XMLSchema"
> xmlns:bpmndi="http://www.eclipse.org/spec/BPMN/20100524/DI"
> targetNamespace="http://www.eclipse.org/spec/BPMN/20100524/MODEL">
> <xsd:import
> namespace="http://www.eclipse.org/spec/BPMN/20100524/DI"
> schemaLocation="BPMNDI.xsd"/>
> <xsd:include schemaLocation="Semantic.xsd"/>
> these files are located in the same directory than the XSD referencing
> them.
That should just work without a catalog. Any relative URIs should be
resolved against the absolute URI of the document containing it, so it
should expect to find these in the same folder.
the thing not clear to me yet is:
on the web these files are at http://www.eclipse.org/spec/BPMN/20100501/, but the URL in the files prefixes with http://www.eclipse.org/spec/BPMN/20100524/MODEL. So i dont know if Eclipse can find and validate XML files build against these schema files will work. Thats why i thought adding them to the catalog. But i dont know the difference between the key types "Schema location" and "Namespace name" when adding a schema file to the catalog. but as u mentioned already, i will ask on WTP forum.
> The issue is that validation of XML files fails...
Does the schema itself validate?
if i open the BPMN20.xsd from a local folder which contains all other referenced XSD files and Validate it, then Eclipse does not complain about it...
> I added the "root" XSD with key type "Schema location" and key
Sounds like a WTP question.
ok. thanks for the hint. unfortunately most of the time i dont know what forum is best to ask questions about Eclipse, therefore long time i avoided asking. But as it is simply not possible to solve everything by myself... i just posted here
Chris
this link posting rule is soo annoying... replace www.eclipse.org with the OMGs .org url if there is a need to use them...
FUDForum. Page generated in 0.25200 seconds
