Resizing Support [message #901780] |
Tue, 14 August 2012 10:50  |
I've implemented a simple shape for my DSL.
It is a Ellipse that contains both a Ellipse and a Rectangle.
Now as per the tutorial resizing the ellipse does not resize the shapes inside of it.
I have looked at the Layout feature however I can't find out how to access the Ellipse and Rectangles contained within the outer ellipse (within the layout feature) let alone attempt to scale them.
Also, I'm not trying to do anything special with the scaling I just want it to be the same as if it was drawn again at that size in the editor. If there any shortcut method I could use to implement this other than scaling everything.
Thanks in advance,
Frank
FUDForum. Page generated in 0.04074 seconds
