Home » Language IDEs » Java Development Tools (JDT) » Not Using the Internal Compiler(Not Using the Internal Compiler)
Not Using the Internal Compiler [message #811880] Fri, 02 March 2012 18:35 Go to next message
I've seen some old answers to this question but not sure if it may have changed in the latest releases. Is there a way to use an external JDK to compile code (without ant scripts) in eclipse, or does eclipse always use the built in ejc to compile code and show warnings (red underlines, gutter messages)? Thanks
Re: Not Using the Internal Compiler [message #811940 is a reply to message #811880] Fri, 02 March 2012 20:42 Go to previous messageGo to next message
It always uses the ejc compiler.
Re: Not Using the Internal Compiler [message #901280 is a reply to message #811880] Fri, 10 August 2012 11:31 Go to previous messageGo to next message
First, I do not know, if this is the right place for this, but google brought me here, so I might as well give it a try Wink
In fact, using it's own compiler causes some trouble in the real world. This is because the compiler that comes with eclipse seems to be a lot more capable than the one shipped with your (or my) JDK.
Especially when generics are used, there seem to be some major shortcomings in current javac implementations (at least for jdk 1.6_x).
So someone can write some amount of code until he or she recognizes that something will not work/compile in the to be shipped product (because ant/maven/gradle will fail to build it using javac).
e.g I got something like the following, which compiles fine in eclipse but fails to compile with javac:
package weird;
public class DoesNotCompile {
   class A<X extends A<X>> {
      class B<Y extends A<X>> {
   class C extends A<C> {
      public C() {
         B<C> b = new B<C>();
         System.out.println("b: " + b.toString());
vs. javac:
formerly-black-sheep:src peter$ javac weird/DoesNotCompile.java
weird/DoesNotCompile.java:12: type parameter weird.DoesNotCompile.C is not within its bound
NOTE: it will not make any difference if the outer class (DoesNotCompile) is left and the classes A and C are put in separate files. Just put them in one file for convenience...
Re: Not Using the Internal Compiler [message #901563 is a reply to message #901280] Mon, 13 August 2012 08:18 Go to previous messageGo to next message
> brought me here, so I might as well give it a try ;)
The same is true if you just stay with javac only: newer versions have
this bug fixed (even if you set the source and target to 1.6) and if you
then switch to another/older version, it won't compile.
Dani
> package weird;
> public C() {
> vs. javac:
Re: Not Using the Internal Compiler [message #901653 is a reply to message #901563] Mon, 13 August 2012 17:48 Go to previous message
Depending on your build tool there should be ways of avoiding this confusion by always using ecj.
For ant see http://help.eclipse.org/juno/index.jsp?topic=%2Forg.eclipse.jdt.doc.user%2Ftasks%2Ftask-ant_javac_adapter.htm
For maven see http://wiki.eclipse.org/Tycho/FAQ#Can_I_use_the_Tycho_compiler_support_in_non-OSGi_projects.2C_too.3F
HTH,
Stephan
Previous Topic:Possible preference change?
Next Topic:Eclipse plugin for GUI design with JQuery UI Components
Current Time: Sat Jul 26 21:50:42 EDT 2025
Powered by FUDForum. Page generated in 0.04524 seconds
