Unable to connect to DB with deployed report [message #901615] |
Mon, 13 August 2012 12:27  |
I am new to BIRT and the BIRT viewer and I am trying to figure out why this is not working. I have a report that works fine in my eclipse BIRT 4.20 environment. When I deploy to a linux/tomcat birt-viewer 4.20 and run the report, it doesn't work and I see this in the logs:
DriverConnectionBase.error.driverDefinitionNotFound: DriverDefn.org.eclipse.datatools.enablement.oracle.10.driverTemplate.Oracle Thin Driver. Using the driver properties defined in database profile instead.
Let me know if you have any ideas.
Thanks!
Re: Unable to connect to DB with deployed report [message #901650 is a reply to message #901648] |
Mon, 13 August 2012 17:00  |
Roger
Can you post the report? BTW if you set the env var for the dtp
workspace, this has to be a directory that the tomcat service has
permission to write to.
Jason
On 8/13/2012 4:16 PM, Roger B wrote:
> Jason,
> Thanks for the reply. Yes, I just confirmed that I did copy the jdbc
> driver jar file to the WEB_INF/lib directory.
> I don't believe I am using a connection profile, because when I go to
> "edit data source" the connection profile tab is empty. Just in case, I
> created the DTP workspace location property anyway, however, after
> restarting everything I am still getting the same error.
> Roger
FUDForum. Page generated in 0.10262 seconds
