Not Using the Internal Compiler [message #811880] |
Fri, 02 March 2012 18:35  |
I've seen some old answers to this question but not sure if it may have changed in the latest releases. Is there a way to use an external JDK to compile code (without ant scripts) in eclipse, or does eclipse always use the built in ejc to compile code and show warnings (red underlines, gutter messages)? Thanks
Re: Not Using the Internal Compiler [message #901563 is a reply to message #901280] |
Mon, 13 August 2012 08:18   |
On 10.08.2012 17:31, Peter Wilhelm Gstettner wrote:
> First, I do not know, if this is the right place for this, but google
> brought me here, so I might as well give it a try ;)
> In fact, using it's own compiler causes some trouble in the real
> world. This is because the compiler that comes with eclipse seems to
> be a lot more capable than the one shipped with your (or my) JDK.
> Especially when generics are used, there seem to be some major
> shortcomings in current javac implementations (at least for jdk 1.6_x).
> So someone can write some amount of code until he or she recognizes
> that something will not work/compile in the to be shipped product
> (because ant/maven/gradle will fail to build it using javac).
The same is true if you just stay with javac only: newer versions have
this bug fixed (even if you set the source and target to 1.6) and if you
then switch to another/older version, it won't compile.
Dani
> e.g I got something like the following, which compiles fine in eclipse
> but fails to compile with javac:
> package weird;
> public class DoesNotCompile {
> class A<X extends A<X>> {
> class B<Y extends A<X>> {
> class C extends A<C> {
> public C() {
> B<C> b = new B<C>();
> System.out.println("b: " + b.toString());
> vs. javac:
> formerly-black-sheep:src peter$ javac weird/DoesNotCompile.java
> weird/DoesNotCompile.java:12: type parameter weird.DoesNotCompile.C is
> not within its bound
> NOTE: it will not make any difference if the outer class
> (DoesNotCompile) is left and the classes A and C are put in separate
> files. Just put them in one file for convenience...
FUDForum. Page generated in 0.04023 seconds
