Home » Modeling » EMF » [CDO] DBStoreAccessor, SmartPreparedStatementCache
[CDO] DBStoreAccessor, SmartPreparedStatementCache [message #898594] Thu, 26 July 2012 14:26 Go to next message
I am still searching for our problems Smile
On my server I have after some days 3637 instances from the class 'org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor' and some of these contain/reference alot of data. The mat - MemoryAnalyzer tells me that these instances contain/reference 350MB of data.
There are only 2 CDOSessions open to the CDOServer, one client is in the same VM and the other client is operating remote. The CDOClient on the server is doing alot transactions and queries, but all in one thread.
These classes have same instance count (in the CDOServer VM):
org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor$ConnectionKeepAliveTask
org.eclipse.emf.cdo.server.internal.db.SmartPreparedStatementCache
(The instances are connected to 'java.util.TimerTask')
The 'SmartPreparedStatementCache' seems to contain the biggest amount of data.
For now I can't reproduce it in a simple testcase Sad
Are about 3600 instance from the class 'DBStoreAccessor' to much?
To search/identify the leak, I have set the h2-cache to a low value and I have disabled the the RevisionManagerCaching for the CDOServer and the CDOClient. Can I do more or should I try something else?
Per Sterner
Re: [CDO] DBStoreAccessor, SmartPreparedStatementCache [message #898647 is a reply to message #898594] Fri, 27 July 2012 00:18 Go to previous messageGo to next message
Am 26.07.2012 20:26, schrieb Per Sterner:
> Hello,
> I am still searching for our problems :)
What exactly are those? Are there any OutOfMemoryErrors being thrown?
What do you mean by "connected"? Do you have a screenshot from MAT?
Stefan, do you think we should pool the store accessors less aggressively? What about a limit on the
StoreAccessorPool.accessors queue? Or a periodic cleanup?
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] DBStoreAccessor, SmartPreparedStatementCache [message #898705 is a reply to message #898647] Fri, 27 July 2012 05:22 Go to previous messageGo to next message
> aggressively? What about a limit on the StoreAccessorPool.accessors
Currently, we assume a rather constant use of concurrent operations
(which are carried out by StoreAccessors). Therefore, the pool in which
StoreAccessors live is not automatically cleaned up. If you have a usage
pattern, where you have peaks of activity and periods of low activity,
you'd have a pool of inactive StoreAccessors which is not cleaned up.
We couls implement a smarter pooling strategy which has a defined
regular amount of elements. If a peek requires more accessors, these are
created and pooled, but if they are inactive for some time, they could
be removed from the pool and freed up until the regular pool level is
reached again.
@Per: If this sounds good, please file a bugzilla for this request.
Stefan
Am 27.07.12 06:18, schrieb Eike Stepper:
>> Hello,
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
Re: [CDO] DBStoreAccessor, SmartPreparedStatementCache [message #898744 is a reply to message #898705] Fri, 27 July 2012 08:34 Go to previous messageGo to next message
Actually the cpu load goes up (~100%, Garbage collector) and therefore (?) a lot TimeoutException occur on transactions.
(I think 'OutOfMemoryErrors' would come later)
INFO   | jvm 1    | 2012/07/27 08:03:50 | Caused by: org.eclipse.net4j.signal.RemoteException: org.eclipse.net4j.util.om.monitor.MonitorCanceledException: org.eclipse.net4j.util.concurrent.TimeoutRuntimeException: Timeout after 10001 millis
INFO   | jvm 1    | 2012/07/27 08:03:50 |       at org.eclipse.net4j.signal.RequestWithConfirmation.getRemoteException(RequestWithConfirmation.java:141)
INFO   | jvm 1    | 2012/07/27 08:03:50 |       at org.eclipse.net4j.signal.RequestWithConfirmation.setRemoteException(RequestWithConfirmation.java:130)
INFO   | jvm 1    | 2012/07/27 08:03:50 |       at org.eclipse.net4j.signal.SignalProtocol.handleRemoteException(SignalProtocol.java:467)
INFO   | jvm 1    | 2012/07/27 08:03:50 |       at org.eclipse.net4j.signal.RemoteExceptionIndication.indicating(RemoteExceptionIndication.java:66)
INFO   | jvm 1    | 2012/07/27 08:03:50 |       at org.eclipse.net4j.signal.Indication.doExtendedInput(Indication.java:57)
I have attached 3 screenshots.
We are syncing some data every 10 seconds (yes polling :-/). But only if new data arrives, this is commited in CDO (But there are always some changes).
>reached again.
I think a smarter cleanup of the pool would solve our problem (screenshots)?
Yes, this sounds good, on my way Razz
Per
Thanks for this project'
  • Attachment: mat_001.png
    (Size: 129.93KB, Downloaded 168 times)
  • Attachment: mat_002.png
    (Size: 148.14KB, Downloaded 167 times)
  • Attachment: mat_003.png
    (Size: 146.38KB, Downloaded 149 times)
Re: [CDO] DBStoreAccessor, SmartPreparedStatementCache [message #899241 is a reply to message #898594] Tue, 31 July 2012 04:21 Go to previous messageGo to next message
Bug report/enhancement: https://bugs.eclipse.org/bugs/show_bug.cgi?id=386289
Re: [CDO] DBStoreAccessor, SmartPreparedStatementCache [message #900530 is a reply to message #898594] Tue, 07 August 2012 08:12 Go to previous messageGo to next message
Hello again,
In our system I modified the cdo server to use the 'org.eclipse.emf.cdo.server.internal.db.NullPreparedStatementCache'.
Then I let it run.
1. At the beginning after a lot queries the Memory looks like this (mat_001_startup.png) (server and one client run in the same VM)
2. After some time (a lot of queries and commits) it looks like this (mat_002.png).
In my logfile there were many exceptions like this:
org.eclipse.net4j.signal.RemoteException: org.eclipse.net4j.util.om.monitor.MonitorCanceledException: org.eclipse.net4j.util.concurrent.TimeoutRuntimeException: Timeout after 11040 millis
 	at org.eclipse.net4j.signal.Signal.doInput(Signal.java:328)
 	at org.eclipse.net4j.signal.Indication.execute(Indication.java:51)
 	at org.eclipse.net4j.signal.Signal.runSync(Signal.java:253)
 	at org.eclipse.net4j.signal.Signal.run(Signal.java:149)
 	at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
 	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
 	at java.lang.Thread.run(Thread.java:619)
 	at org.eclipse.net4j.util.om.monitor.Monitor.checkCanceled(Monitor.java:56)
 	at org.eclipse.net4j.util.om.monitor.TimeoutMonitor.checkCanceled(TimeoutMonitor.java:116)
 	at org.eclipse.net4j.util.om.monitor.NestedMonitor.checkCanceled(NestedMonitor.java:55)
 	at org.eclipse.net4j.util.om.monitor.AbstractMonitor.hasBegun(AbstractMonitor.java:36)
 	at org.eclipse.net4j.util.om.monitor.AbstractMonitor.checkBegun(AbstractMonitor.java:141)
 	at org.eclipse.net4j.util.om.monitor.AbstractMonitor.fork(AbstractMonitor.java:65)
 	at org.eclipse.net4j.util.om.monitor.ProgressDistributor.run(ProgressDistributor.java:86)
 	at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicatingCommit(CommitTransactionIndication.java:262)
 	at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicating(CommitTransactionIndication.java:96)
 	at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndicationWithMonitoring.indicating(CDOServerIndicationWithMonitoring.java:109)
 	at org.eclipse.net4j.signal.IndicationWithMonitoring.indicating(IndicationWithMonitoring.java:86)
 	at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedInput(IndicationWithResponse.java:92)
 	at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:65)
 	at org.eclipse.net4j.signal.IndicationWithMonitoring.execute(IndicationWithMonitoring.java:65)
 	at org.eclipse.net4j.util.om.monitor.TimeoutMonitor.handleTimeout(TimeoutMonitor.java:121)
 	at org.eclipse.net4j.util.om.monitor.TimeoutMonitor$1.handleTimeout(TimeoutMonitor.java:61)
 	at org.eclipse.net4j.util.concurrent.Timeouter$1.run(Timeouter.java:88)
 	at java.util.TimerThread.mainLoop(Timer.java:512)
 	at java.util.TimerThread.run(Timer.java:462)
The h2-DB has grown a bit (1.5GB), perhaps the exceptions are okay. But the instance count of 'org.eclipse.emf.cdo.internal.server.Transaction' is too high? Are they not closed?
I looked in my code, the Transactions on the client side are closed on an exception.
regards,
Per Sterner
Re: [CDO] DBStoreAccessor, SmartPreparedStatementCache [message #900568 is a reply to message #900530] Tue, 07 August 2012 10:54 Go to previous messageGo to next message
Hi Per,
This is a follow-up effect of the store accessors being pooled but never released in phases of low load.These
transaction must be inactive but still referenced via StoreAccessorBase.context.
Cheers
/Eike
Am 07.08.2012 14:12, schrieb Per Sterner:
> Hello again,
> Then I let it run.
> regards,
> Per Sterner
Re: [CDO] DBStoreAccessor, SmartPreparedStatementCache [message #901516 is a reply to message #900568] Mon, 13 August 2012 04:34 Go to previous messageGo to next message
as Eike suggested i tried to look into the DBStoreAccessor, but i have still some questions.
As Per wrote the ConnectionKeepAliveTask is one of the classes not being cleaned up. So i wanted to ask if thats because the DBStoreAccessor is pooled? Is this task stopped when the Accessor gets removed from the pool?
I tried to comment this part(DBStoreAccessor.doActivate) out:
  protected void doActivate() throws Exception
    DBStore store = getStore();
    connection = store.getConnection();
    // connectionKeepAliveTask = new ConnectionKeepAliveTask();
    // long keepAlivePeriod = ConnectionKeepAliveTask.EXECUTION_PERIOD;
    // long keepAlivePeriod = 1000L * 60L;
    // Map<String, String> storeProps = store.getProperties();
    // if (storeProps != null)
    // String value = storeProps.get(IDBStore.Props.CONNECTION_KEEPALIVE_PERIOD);
    // if (value != null)
    // keepAlivePeriod = Long.parseLong(value) * 60L * 1000L;
    // store.getConnectionKeepAliveTimer().schedule(connectionKeepAliveTask);
    // TODO - make this configurable?
    statementCache = CDODBUtil.createStatementCache();
    statementCache.setConnection(connection);
    LifecycleUtil.activate(statementCache);
As result all classes were removed correctly and didn't leak(DBAccessor, etc.). So I got the feeling that this ConnectionKeepAliveTask prevents the DBStoreAccessor from being garbage collected? (or did i get something wrong?)
Second, i wanted to ask for some hints where to look for the "Pooling-Strategy". I found the pools itself but not how and where they are cleaned up.
Christian
PS: I wrote it here because i think it doesn't belong into the Feature-Request
[Updated on: Mon, 13 August 2012 04:38] by Moderator
Re: [CDO] DBStoreAccessor, SmartPreparedStatementCache [message #901532 is a reply to message #901516] Mon, 13 August 2012 05:26 Go to previous messageGo to next message
Well nevermind, you implemeted the Feature already :/. Sorry for my late questions. Your comment #5 on the Feature-Request seems to fit to my first question.?
Re: [CDO] DBStoreAccessor, SmartPreparedStatementCache [message #901534 is a reply to message #901516] Mon, 13 August 2012 05:32 Go to previous messageGo to next message
Hi Christian,
Please note that I've resolved https://bugs.eclipse.org/386289 in the meantime. Please feel free to reopen if you have
additional suggestions ;-)
Cheers
/Eike
Am 13.08.2012 10:34, schrieb Christian Mohr:
> @Override
> ConnectionKeepAliveTask prevents the DBStoreAccessor from being garbage collected. (or did i get something wrong?)
> Christian
> PS: I wrote it here because i thinnk it doesn't belong into the Feature-Request
Re: [CDO] DBStoreAccessor, SmartPreparedStatementCache [message #901535 is a reply to message #901532] Mon, 13 August 2012 05:33 Go to previous messageGo to next message
Am 13.08.2012 11:26, schrieb Christian Mohr:
No worries ;-)
Yes.
Cheers
/Eike
Re: [CDO] DBStoreAccessor, SmartPreparedStatementCache [message #901702 is a reply to message #901535] Tue, 14 August 2012 04:39 Go to previous messageGo to next message
Thanks.
[Updated on: Tue, 14 August 2012 04:41] by Moderator
Re: [CDO] DBStoreAccessor, SmartPreparedStatementCache [message #901703 is a reply to message #901702] Tue, 14 August 2012 04:55 Go to previous message
Am 14.08.2012 10:39, schrieb Christian Mohr:
> Hi Eike,
> am i allowed to ask where i can find the changes? I wasnt' able to locate it neither in the "master"-branch
My fault! I forgot to push master. Please try again...
Cheers
/Eike
Previous Topic:[CDO] java.lang.illegalStateException
Next Topic:Handle more than one editor plugin
Current Time: Tue Jul 22 22:23:36 EDT 2025
Powered by FUDForum. Page generated in 0.06147 seconds
