Jubula: Rename a GMF element [message #900736] |
Wed, 08 August 2012 07:04  |
I am writing functional test cases from a gmf application. This application has a "palette" from where the gmf elements are selected and then dropped on the "canvas". These elements can be named be clicking in the editable area inside the element.
Using Jubula "gef toolkit : figure canvas" I am able to select the element from palette and drop it on the canvas. However I am unable to find a test case through which I am name the dropped element.
I am able to identify the name of the editable area inside the element using the GEF inspector. But that isn't helping much. Is there anything I can do with it?
Jubula Object Mapping recognizes the canvas but not the individual elements inside the canvas, so "input via keyboard" option cannot be used.
Also since the elements are of the type "figure canvas" , in order to give a name to the element, do I have to find a test case of the type "figure canvas"??
I would greatly appreciate any help!!
Thank you,
Vidya Bhat
FUDForum. Page generated in 0.24529 seconds
